L92 on LS2 Cam question
I would recommend you look for a cam in the high 220s/low 230s. I wouldn't go to much bigger than that and stay around 600 on the lift and not much more than that. I plan on doing a cam in the coming year. I will be doing a QM custom cam, staying right around these specs. It will make great power and will idle well. But, will not lose any drivability.
Review this article by SpinMonster. He has done several L92 head and cam swaps and has the actual measurements on what will fit.
http://forums.corvetteforum.com/show...ight=l92+heads
I've read it before and its based on the premise that to run a big cam you must Fly cut the pistons, which is something I don't want to do.
ET 215 Heads, cam, fast intake
Apr 30, 2008
1st pass. 11.042 @ 130.24 mph 1.75 60 ft. 3200 rpm.
2nd pass 1.57 60ft. 4200 rpm, clutch pedal stuck to floor for a couple of seconds shifting to 3rd.
3rd pass clutch pedal stuck to the floor again shifting to 2nd.
I suspect the headers and the friction from the clutch are boiling the clutch fluid.
Subject not about Cams but I'm trying to PM back to you but it says that you exeeded your stored private message quota and will not exept messages until you clear some space.
Don
I would think milled that far, even with a 224 XER, would require serious verification of the P/V distance.
You didnt mention the valves you are using either. If you are using aftermarket vavles (one piece stainless) then the clearance with milling will require flycutting with a 224 XER. The manley raceflo valves for example, have .030" thick margins on the heads of the valves which take close to that much away from P/V clearance. With .025" milled on one application, I had .093" clearance with a stock GM valve. This was with a 228 XER cam. The same set-up with a manley intake valve would be .063"....too close.
Another point to consider is the source you get the cam from. All cams have a variation from the published specs and many can be ground wrong. Cartek verifies all thier cams on a cam doctor and some from their cam source go bakc becuase they are too far from spec. If a cam is supposed to be 224/228 and it comes ground to 225.1/227.2 113.4LSA, its considered to be in spec but wont clear with the same distance as the same cam ground on a different day that came out to be 223.6/227.6 114.2 LSA.
Big cams that fit with stock heads will not mean they fit with L92's milled. In fact they wont.
Lastly, guys making 450-460rwhp with no milling or flycutting have gotten 470rwhp with cams as small as a 224. The TQ of the cam only cars that make in the 435-450rwhp with the X3 do not make more than 385-400rwtq while the L92's with the same 224 cam will get you 40-50rwtq more and much more HP under the curve.
Now mixing the two makes a potent combo. The L92's with fly-cutting will net you near 490rwhp and 440rwtq.
If you take no advice other than this you're doing the minimum: Dont try to design the entire package on your own. Get a tuner involved or go with a proven package.
Apr 30, 2008
The clutch fluid has nothing to do with the clutch slipping and not being able to handle 500rwhp which your traps speeds indicate you have now. That clutch doesnt hold that much. My LS2 went south in a month when I was at 450rwhp.
What compression are you running? What valves are you running? Who di
Are you doing the install?d the install?
http://www.stjude.org/stjude/v/index...000e2015acRCRD
