FM Antenna Location
Old May 19, 2008 | 08:41 AM
Duke1947's Avatar
Duke1947
Navigator
Default FM Antenna Location
Still looking for anyone that has an idea where the FM antenna is hidden. I think I may have found a possible spot. In the passenger sun visor mount. There seems to be a small hole next to the mounting screw hole that has a small glass bead connected to two small wires and a clip connector. Am I on the right track here.
Old May 19, 2008 | 10:01 AM
danl72's Avatar
danl72
I think what you are refering to is the LED light. It is mounted in the passenger side sun visor mount. It is to give some light at night.
Old May 19, 2008 | 10:22 AM
Duke1947's Avatar
Duke1947
Navigator
Thanks for the feedback Calif. I did get some info to look in the trunk for some wires running across the back and a box........... Go figure. Just have to amke sure I get the FM Lines and not the AM lines to hook up my XM........
Old May 19, 2008 | 01:43 PM
overrev64's Avatar
overrev64
The antenna is located inside the rear bumper cover between the cover and the rear bulkhead.
Old May 19, 2008 | 02:59 PM
johnodrake's Avatar
johnodrake
Moderator
To FM Antenna Location
