I bought a '05 coupe with 4000 mi. the dealer tells me this is not a Z51, but it has the large drilled and slotted brakes. Is there a way to tell a Z51 from a base coupe? Thanks....
If the rotors have slots, they are not the factory rotors. Z51 rotors are cross-drilled only. NewC6Guy stated the only way to absolutely tell if it is a Z51.
Thanks for the help guys! My mistake, the rotors are drilled but not slotted. Looked in the glove box but I don't know what to look for. The vin is 1G1YY24U155106917
There is a sticker in the glove box (I don't remember if it is on the actual door like the C5) that states all the Regular Production Option (RPO) codes. If it is a Z51, that code will be there.
Yup, not a Z51 according to the build RPOs. Someone swapped on the rotors. Back in early 05 Z51s were tough to get, always on constraint. Someone probably got tired of waiting and got one without, then swapped out the rotors. They do fill out those front wheels nice. Have those calipers done up in that DSOM orange, and that will be one sharp car.
Hey Glenn, comming to the race I suppose. I hope you enjoy yourself! I'll be driving the track on Sat. with one of the local dealers, should be a blast!
