What tire pressure do you keep?
May 19, 2008 | 02:00 PM
May 19, 2008 | 02:33 PM
May 19, 2008 | 02:44 PM
Quote:
Originally Posted by
SvetteC6
30 psi cold
May 19, 2008 | 02:54 PM
danl72
May 19, 2008 | 04:22 PM
Yes, I'm just dumb enough to run what the manufacturer says to run - 30 psi when cold.
May 19, 2008 | 04:25 PM
St. Jude Donor '15
"In honor of jpee"
May 19, 2008 | 04:50 PM
St. Jude Donor '10-'11
hmmmm ikeep 27 in rear you think thats bad
May 19, 2008 | 04:55 PM
29 rear / 30 front on Pilot Sports
May 19, 2008 | 05:10 PM
30 psi cold spring and fall
28 psi cold in the summer (when pavement is a lot hotter and hot pressure jumps at least4 psi)
May 19, 2008 | 05:21 PM
Generally, around 30. But, I let it vary between 28-32.
May 19, 2008 | 08:32 PM
I've been running 36 front / 33 rear in the PS2s, may go a little higher. The stock Goodyears seemed to like lower pressures, around 28 - 30 PSI.
May 19, 2008 | 10:37 PM
Bad06vette
May 19, 2008 | 10:52 PM
30 front 24 rear hot
May 20, 2008 | 07:36 AM
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
dennis50nj
24 rear hot
do you get a 'low pressure warning' ?
May 20, 2008 | 07:37 AM
Cold (ie not driven)
front: 30
rear: 28
May 20, 2008 | 11:03 AM
SvetteC6
30 psi cold
Same and re check twice a month.
May 20, 2008 | 11:10 AM
yes until the tires warm to 24lbs then it goes off that way i know not to step on the gas until the low pressure warning goes out
May 20, 2008 | 11:31 AM
St. Jude Donor '21 thru '26
30 psi cold, front and rear. I check them once a week with a good tire gauge. Leif
May 20, 2008 | 07:11 PM
SvetteC6
30 psi cold
me too
May 20, 2008 | 07:17 PM
johnodrake
