P0050 P0064 codes help please!
Old May 20, 2008 | 12:17 AM
Z51 6spd's Avatar
Z51 6spd
Default P0050 P0064 codes help please!
Hey guys I did a search and I can't find anything on the P0050 or P0064 codes. My friend has a nice scan tool but it can't tell us what these codes are. We have never had this problem before, anybody have an idea of what's going on. We have erased them but they come right back.
The car is Magnacharged with full exhaust, but seems to be running ok. In advance I want to say thanks for everyone reading this, this forum is great.
Old May 20, 2008 | 05:24 AM
Sparky65's Avatar
Sparky65
FAULT CODE: P0050
Monitor Strategy Description: O2S Heater Control Circuit Bank 2 Sensor 1
SENSED PARAMETER: This DTC checks the Heater Output Driver circuit for electrical integrity
MALFUNCTION CRITERIA AND THRESHOLD VALUE(S): Voltage low during driver open state (indicates short-to-ground or open circuit) or voltage high during driver closed state (indicates short to voltage).
SECONDARY PARAMETERS AND ENABLE CONDITIONS:
• Ignition switch is in crank or run
• Ignition Voltage 11-18 volts
• RPM Greater Than 425
TIME LENGTH AND FREQUENCY: 20 failures out of 25 samples Frequency: 250ms loop, Continuous
MIL ILLUMINATION TYPE: DTC Type B
Can't find DTCP0064
Old May 20, 2008 | 05:49 AM
Mr.Big's Avatar
Mr.Big
P0064....HO2S Heater Control Circuit High (Bank 2 Sensor 3)
Old May 20, 2008 | 06:16 PM
Z51 6spd's Avatar
Z51 6spd
Thanks guys I will tell my mechanic friend, and let you guys know what the outcome is.
To P0050 P0064 codes help please!
