installing braided steel brake lines
Old May 20, 2008 | 01:16 AM
openhelix's Avatar
openhelix
Default installing braided steel brake lines
I vaguely remember doing these on my f-body a long time ago. What all is involved to replace the stockers with braided lines? While I'm at it, how much fluid will I need to do a full flush? Castrol SRF still the best out there?
Old May 20, 2008 | 01:24 AM
naschmitz's Avatar
naschmitz
First off, I think the braided steel brake lines are a waste of time. I decided to install them when I had my calipers powdercoated but it made the job three times more difficult.
You can't really see them and there is no difference in pedal feel once they are on.
I used the $12 1 liter ATE Super Blue / Amber high temp brake fluid to do the brake line / caliper swap and it was plenty.
Old May 20, 2008 | 04:58 AM
986_C6's Avatar
986_C6
I use the ss lines in my other car and it gives a much firmer pedal feel (this is also from experience in the roadcourse tracks). Haven't changed the vette lines yet, but should give the same result.
I also use the Ate Super Blue.
Old May 20, 2008 | 05:42 AM
mvcrash's Avatar
mvcrash
I agree with the change in pedal feel.
Old May 20, 2008 | 06:24 AM
EuroRod's Avatar
EuroRod
Just make sure to use a DOT 4, or better, fluid, and bleed them beginning with the RR, then LR, then RF, and finally LF.
Old May 20, 2008 | 11:26 AM
CMY SIX's Avatar
CMY SIX
it was easy I got the brake bleeder from ZIP PRODUCTS $55.00 and did it myself in a couple of hours sucked the tank out before I started put fluid in and ran enuff through to flush and there is a big difference in pedal feel and at high temps they will not expand like the rubber will{mushy pedal feel}
To installing braided steel brake lines
By Michael S. Palmer | 2026-06-03 09:39:05
