ABS malfunction
Although something I usually only encounter at the end of the strip, and that goes away when I turn off/and turn back on the car...it's still a cause for concern that the dealership can't obviously reproduce and one that I don't care to explain to them.
If you're running some different wheels/tires, especially something that changes the ratio of the front to rear wheel diameters, then that's almost certainly what is causing it.
Bob
They have replaced a wheel spd sensor and the ABS Control Module, guess what, still comes on.
If I had to guess, it's still a wheel spd snsr. And I would speculate yours is too.
Are there any warranty implications to me since this only happens at 120mph? Or how about even telling them about it cause any headaches? Thanks for the input so far.
Also, the data logging isn't going to be long term, at best maybe 15 mins or when the light comes on depending on what they propose to use.
Have they scanned it for any ABS codes?
It may "HOLD IT" for decades, but how much TIME will it actually record.
Other than dedicated programs, most scanners designed for the automotive tech will not record hours of data as some may fear.
Here is how the Tech2 operates
Trigger Type (F0 - F3 function keys) determines how the snapshot is triggered:
F0: Manual Trigger triggers a snapshot when you press the Trigger soft key.
F1: Any Code triggers a snapshot whenever any current trouble code is stored. This event occurs
when the first code is stored in the vehicle controller memory.
F2: Single Code triggers a snapshot when a user specified trouble code is stored.
F3: Automatic Trigger (chassis applications only) automatically triggers a snapshot.
Trigger Point (F4 - F6 function keys) is the exact point at which the trouble code (fault) or manual
trigger occurs within the snapshot period. It helps to know the trigger point when you are looking for
changes in data parameters. Trigger point may be set for:
F4: Beginning causes the Tech 2 to start recording information from the trigger point until
snapshot storage is full. This choice is useful if the fault is predictable.
F5: Center is the most commonly used trigger point because it stores information leading up to
and following the trigger point. This function allows comparison of events before, during, and
after a fault.
F6: End sets the trigger point at the end of the snapshot recording and therefore shows only
They replaced the EBCM and it looks like the problem is fixed.
after a fault.
Im glad they finally fixed it for you
Im glad Im not the only one whose had to go to the dealer a few times for the same thing
Ihad problems with the seals between the trans and rear
Mike
My guess is he was just testing every sensor he could and finally ran some sort of test on the EBCM to test the internal circuits when finally finding the short.
I'm sure they probably have proprietary equipment to test it out.
