A/C compressor - constant HP draw?
Old May 23, 2008 | 01:02 PM
From C6ZO62C8's Avatar
From C6ZO62C8
Originally Posted by SpinMonster
It turns off under WOT or at a preset rpm if you tune it that way.
It should cut out under WOT or high RPMS but when I have my a/c on my car feels dead, so I toggle the a/c switch on/off when I need to hit the gas
Old May 23, 2008 | 01:22 PM
Braumeister's Avatar
Braumeister
You could hook a MSD rpm activated switch in series with the clutch switch and set the rpm to cutout the compressor anywhere you want...Pete
Old May 24, 2008 | 10:02 AM
c6 Houston's Avatar
c6 Houston
Default ac on/off?
Don't know if it works for sure but this is what I did with HP Tuners.
Stock was set for: I changed to:
Disable RPM 7083 2800 RPM
Re-Enable RPM 7083 2500 RPM
Disable TPS 200% 55%
Re-Enable TPS 197% 50%
I am trying to test this. I'm a noobie at HPT.
I don't know if both or only one of the parameters (RPM, TPS) has to be met.
