I received my second green filter and green recharge kit from Vararam yesterday. Does the filter come already preoiled or do I have to oil it? I don't want to over oil it if it has been done already.
And by the way, using the pressure washer to clean my old filter did not work as well as I had hoped. Lots of little pin holes on the top of the filter. I tried.
just soak in cold water and dawn rinse, i dont oil it
They specifically say in the instructions to NOT use high pressure when cleaning these mesh/gauze type filters.
I saw that in the instructions I just received with the green recharge kit. Yes, both you and they are correct. Now back to my original question, does the new filter come pre-oiled???
When the man with the time of 10.927 @ 123.63 1/4 speaks, I listen!
Did I tell you how much I enjoyed that video?
Why don't you use the oil?? And more importantly, how often do you clean your filter.
I just pulled mine out at 1200 miles to replace it with the new filter and I couldn't believe how much grit and sand was there in that short period. I also pulled out a pebble/small rock from the filter. Scary.
thanks here's another one from the last track rental may 15 the da was a +2400 so not to bad of a time i think it still could have went 10s but i had to leave early and couldnt let it cool down to the temp i like.
i dont change the filter or clean or oil. i take it out tap it, put it back in http://www.cartek.net/videos/dennis1108.wmv
thanks here's another one from the last track rental may 15 the da was a +2400 so not to bad of a time i think it still could have went 10s but i had to leave early and couldnt let it cool down to the temp i like. http://www.cartek.net/videos/dennis1108.wmv
Nearly 80 degree temps, barometer in the 29.xx range and still amazing results.
I dont oil my filters for the VR. Any amount of oil on there will cause somewhat a restriction. It also wouldnt take much oil film to upset the MAF sensor calibration. I know VR suggests a light coating of oil in their
replacements & after cleaning. I would just rinse it off under the sink, let it dry and replace it. Just my opinion.
And I appreciate your opinion. Obviously, it works for Dennis. Thanks for the video Dennis. Makes me want to try that myself!
I would think the oil would capture smaller particles than a dry filter. I also think a dirty filter would be a restriction and I am finding the filter gets very dirty, very quickly. I will attempt to clean my filter no later than 2000 miles or so. To simplify the cleaning process, I will order a spare filter so I don't have to wait overnight for it to dry.
Anyone else out there that does not use oil on their green filter??
Where's the best (i.e. cheapest) place to get the green oil kit for cleaning and re-oiling your filter?
We have the Green Filter Recharge kits available for $15.95 plus $8 shipping(sorry!). The kit comes with cleaner and oil and will be good for 6-8 uses!!! Call me at 866-507-2648!!
Steve
