High auto transmission temps?
Old May 23, 2008 | 02:37 AM
RadarP3C's Avatar
RadarP3C
Default High auto transmission temps?
I have started to monitor the transmission temp of my A6. Today the outside air temp was 85 degrees and I was stuck in stop and go traffic. The transmission temp creeped up to 207 degrees. When traffic started to move again, the trans temp dropped down into the 180’s. The water temp never got above 210 degrees.
The high temps of summer aren't here yet, so what is considered a high auto transmission temp?
Old May 23, 2008 | 02:46 AM
Evilways's Avatar
Evilways
At 240-260 degrees, the trans may make a DIC readout that says to slow car or let trans cool down (paraphrasing the manual). Since the stock trans cooler allows the engine coolant to run through, you may see slightly higher than coolant level temps in the trans temp readout. My A6 had catastropic failure at 260 degrees, according to the tech that disassembled it to verify it was indeed a factory parts failure and not abuse.(it has a sort of data recorder in it's computer).Using the paddles will also increase the temp to a higher level faster than letting it shift it's self.
Old May 23, 2008 | 10:29 AM
RadarP3C's Avatar
RadarP3C
Thanks, Evilways!
Old May 23, 2008 | 11:57 AM
danl72's Avatar
danl72
Thanks for the info.
Old May 23, 2008 | 03:50 PM
Busa196's Avatar
Busa196
Damn, I feel better. I've got an A4 with a 3200 stall and a stage 5 tranny with a B&M tranny cooler/with a fan- my temps in 90-100 degree weather do almost the same as yours- maybe even a little cooler. Either way, we're both OK
It took me lots of time/money/trials to figure out how to make mine run that cool with my set-up.
Old May 28, 2008 | 10:28 PM
IceN's Avatar
IceN
so what is everyones cruising temp and idle temp in traffic.
Today was 97ish degrees out
cruising temp was around 197
idle temp crept up to 208
is this normal. Just wanna make sure because my headers are maybe 3 or 4 inches away from where the tranny fluid circulates.
Old May 29, 2008 | 01:14 AM
LS2POWA's Avatar
LS2POWA
With a 3200 stall on an A6 and b&m tranny cooler i run 200-210 idling and in the mid 190s cruising. My first tranny cooler got smashed the other day and yeah seeing 252* 1 block from the shop is a scary thing. now im good lol. today was around 94/95* , good ole florida heat. now i just gotte figure out how to not overheat the alternator and im good.
Old May 29, 2008 | 02:24 AM
keyplyr's Avatar
keyplyr
Originally Posted by Busa196
I've got an A4 with a 3200 stall and a stage 5 tranny with a B&M tranny cooler/with a fan...
I've got pretty much the same set-up as you, and from what I've researched, temps up to about 130 are safe.
Old May 29, 2008 | 07:15 AM
NYC6's Avatar
NYC6
I heard somewhere if your stuck idleing for a long peroiod of time( stuck in stop and go traffic, long red lights etc.) putting trans in nuetral will take strain off and allow it to cool more easily. I do it when I can.
Old May 29, 2008 | 08:13 AM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Do you mean 230?
To High auto transmission temps?
