Will an LS3 intake work on a LS2 Engine?
Old Jun 1, 2008 | 02:38 PM
ydlee24's Avatar
ydlee24
Default Will an LS3 intake work on a LS2 Engine?
Will a LS3 intake work on a LS2 Engine with a slight performance gain?
Old Jun 1, 2008 | 03:24 PM
Braciole's Avatar
Braciole
St. Jude Donor '08
From what I understand its the basically the LS2 with better heads (LS3)
the different heads wont let you use the intake
correct me if Im wrong guys?
Mike
Old Jun 1, 2008 | 03:28 PM
johnodrake's Avatar
johnodrake
Moderator
Mike
Nope, you are quite correct. LS2 has cathedral ports and LS3 has rectangular ports.
Old Jun 1, 2008 | 05:12 PM
Modshack's Avatar
Modshack
An Air intake won't work either as the MAF is totally different..
Old Jun 1, 2008 | 05:54 PM
Corellian Vette's Avatar
Corellian Vette
Different intake ports. If you swapped your heads with L92/LS3 then they would work.
To Will an LS3 intake work on a LS2 Engine?
