After Installaing The Vararam.......
Old Jun 9, 2008 | 03:35 PM
slverbulletz06's Avatar
slverbulletz06
Default After Installaing The Vararam.......
Alight Here we go again.... I recently installed the vararam and now whenever im slowing down my car starts to hesitate and the Air Mass Flow Sensor is mounted correctly and facing the right way.. Has Anyone delt with this situation before??
Old Jun 9, 2008 | 03:42 PM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
Make sure there are no vacuum leaks. Did you install the TB Spacer?
Old Jun 9, 2008 | 03:53 PM
slverbulletz06
Yes i did! It was the Varam Stack!
Old Jun 9, 2008 | 03:56 PM
Braciole's Avatar
Braciole
St. Jude Donor '08
Let me ask a stupid question.......
Did you disconnect the battery after your install???
Mike
Old Jun 9, 2008 | 04:05 PM
slverbulletz06
No But i did Before and during not after..
Old Jun 9, 2008 | 05:19 PM
jmudreamvette's Avatar
jmudreamvette
I had a tuner help with install with mine after doing a TB & manifold port. Was he suppose to do that? Disconnect the battery...
Old Jun 9, 2008 | 08:34 PM
03 Z-oh-6's Avatar
03 Z-oh-6
Doesn't need to be done.
Old Jun 9, 2008 | 08:42 PM
Whaler21's Avatar
Whaler21
I don't think the instructions said to disconnect the battery. I didn't disconnect mine when I did my install. I figured if it was important they would include it in the instructions.... but, on the other hand I have seen much better instructions in my day. Like the time I bought my kid a bike made in China, and all the instructions were written in chineese .
Old Jun 9, 2008 | 09:29 PM
Braciole's Avatar
Braciole
St. Jude Donor '08
its imperative you diconnect the battery after each and every
Mod, or you stand a good chance of throwing CELs
The computer gets conflicting info and throws codes
Its a fact.
Its a good thing you did, but im afraid you have another issue
make sure you go over everything again loose wires, see if anything is pinched, you have the mas going the right way LOL
you get the point
Mike
Old Jun 9, 2008 | 09:59 PM
03 Z-oh-6's Avatar
03 Z-oh-6
Its a fact.
you get the point
Mike
My car was tuned right after the install of the vararam, so it wouldn't affect me if the battery was disconnected or not. If disconnecting the battery was THAT important, I'm sure it would have been stated in the instructions.
Old Jun 10, 2008 | 12:08 AM
slverbulletz06
Wellit only does it when im in gear and whenever i just put it in neutral it just goes away its one thing after another with these cars its getting really annoying i think i just have bad luck with this vette!!!!!!
Old Jun 10, 2008 | 07:43 AM
VaraRam Industries's Avatar
VaraRam Industries
Supporting Vendor
St. Jude Donor '07-'11-'12
Call our tech line at 713-899-6456 and talk with them!!!!!
Steve
Old Jun 11, 2008 | 11:57 AM
not08crmanymore's Avatar
not08crmanymore
Check your connections.
Did you remove any maf screens?That would do it too.
You might have something not connected up all the way.Never had any issue w/my V-RAM when I had one.
Old Jun 11, 2008 | 02:06 PM
StoplightWarrior's Avatar
StoplightWarrior
I didn't disconnect my battery when I installed my Vararam, and I've never had any problems.
Old Jun 11, 2008 | 03:58 PM
Nd4spd2's Avatar
Nd4spd2
St. Jude Donor '08
Its a fact.
you get the point
Mike
You can just pull the ecm fuse (#11 on my 08) - it's easier
Old Jun 11, 2008 | 05:08 PM
A-Pex's Avatar
A-Pex
Would you recommend going to a shop for tuning and/or buying a tuner and adjusting the system after installing the Vararam?
Old Jun 11, 2008 | 11:45 PM
slverbulletz06
When I bought my Zo6 it didnt come with a screen in it.... but its weird bc I took out that vararam stack and it kinda went away.. My tranny is going out(no 2nd gear & 1st on its way) I dunno If that has to do with anything...
To After Installaing The Vararam.......
Old Jun 11, 2008 | 11:52 PM
BigSlick's Avatar
BigSlick
hope you get it fix up...
Old Jun 12, 2008 | 08:58 AM
Ragtop 99's Avatar
Ragtop 99
On a manual tranny car, you don't have the MAF influencing line pressure, so your Vararam did not lead to your tranny's demise.
Maybe a few missed shifts or lack of rev matching on downshifts would be more likely culprits.
Old Jun 12, 2008 | 04:27 PM
slverbulletz06
I know when i bought the car with about 60k on it i had to have a local tuner adjust the timing on it because it was dedinating or whatver...
