DIY Cam Swap
I will be taking it to LG Motorsports on Friday for the tune. Those guys do a really awesome job!
And so it starts...LS2!
Removal of VaraRam Intake
Good view of the LG Longtube Headers. These are paired with some Corsa Sports.
Car on jackstands
Removal of cooling fan
A steering rack end link...the rack removal was a bitch. The installation was MUCH easier.
Timing Cover...almost there!
Cam Gear...almost there!
Removal of stock cam
Installation of new cam (Comp XER273)
Alomst installed. It was tough to get it over that last bearing. The use of the water pump bolts in the cam retainer holes was a must.
The underdrive pulley was a bitch to take off. Followed proper installation (240 lb/ft installation pass with old bolt, 37 lb/ft 2nd pass, 140 degrees final pass)
Changing valve springs (Comp 921)
Good view of new springs
JOB COMPLETE...it is such a great feeling when it fired right up without any problems.
CHEERS!
If any of you guys have any questions about this, PM me. Thanks!
Scott
Another bit of advice is to replace the front seal. I'm now removing everything for the (first=cam swap, second=o-ring) third time to fix a leak which appears to be coming from the front seal...
I used the "Tim's Valvespring Tool" that can be ordered from LS1Tech.com as well as Tim's tool to send compressed air into the cylinders to keep the valves up when changing the springs. Both tools are pretty low tech, certainly not as fancy as the Thunder Racing bollet piece, but they do the job well and are budget priced.
Scott - Did you remove the PS pump in order to disconnect the PS rack lines?
I did not touch the oil pump. Why do you recommend changing the o-ring? Also, I throughly inspected the front seal and found no damage or indications of wear, so i reused.
Thanks for the advice. I will keep in mind the next time I change oil pump.
I do like that fancy spring tool, I was cheap and used a "Larry" tool off of LS1Tech.com. I also used top dead center method to hold the valves up, it appears you used compressed air which works much better!
Excellent job!
I had to remove the pump because I could not see the timing dot on the crank sprocket. Here's why I say to change it out and be super careful putting the pickup back on: http://forums.corvetteforum.com/show....php?t=1991993
I didn't see anything wrong with my front seal either. I'm halfway through tearing it down again to inspect it. Hopefully it's apparent that it is the cause.
Anyway, beauty job!
Anyway, beauty job!
Mike
