Help Locked Out
Old Jun 12, 2008 | 02:00 PM
aspenripper's Avatar
aspenripper
Default Help Locked Out
ANYONE KNOW WHERE I CAN HOOK A BATTERY CHARGER TO CHARGE DEAD BATTERY ON Z06, KEYS INSIDE, 2 DELAER CUT KEYS DO NOT WORK. CAR IN MY GARAGE ALREADY TRIES GETTING IN THRU TAIL LAMP NO LUCK
tHANKS
eD
Old Jun 12, 2008 | 02:26 PM
mike72's Avatar
mike72
you can try jacking it up and running jumper cables to the starter connection.
Old Jun 12, 2008 | 02:28 PM
danl72's Avatar
danl72
Old Jun 12, 2008 | 02:33 PM
aspenripper
Thats My Plan Now Passenger Side I Take It
Old Jun 12, 2008 | 02:56 PM
VET4LES's Avatar
VET4LES
It's on the passenger side.
Old Jun 12, 2008 | 03:03 PM
aspenripper
Well Any Bets On If This Will Work
Old Jun 12, 2008 | 03:08 PM
Modshack's Avatar
Modshack
It's a direct feed to the battery so there's no reason it won't!
Old Jun 12, 2008 | 03:30 PM
aspenripper
UNLESS YOU HAVE THE LUCK i DO THIS WEEK
Old Jun 12, 2008 | 03:40 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
.....disconnect the cable from starter motor as a safety precaution & attach the positive line from the battery charger to the cable end....
Old Jun 12, 2008 | 03:51 PM
nelsond003's Avatar
nelsond003
u can call 1-800-4onstar. they will unlock it for u. the battery should have enough juice to unlock the doors??? but if its that dead, then I dont know???
Old Jun 13, 2008 | 09:15 AM
aspenripper
Default In Now
ROADSIDE SENT A KEY FROM LOCAL LOCKSMITH CUT WITH KEY CODE PERFECT. lOCAL DEALERS KEY DID NOT WORK AFTER 2 KEYS MADE
To Help Locked Out
