Question about Koni FSD shocks
Old Jun 18, 2008 | 07:31 PM
csun213's Avatar
csun213
Default Question about Koni FSD shocks
I have a set of Koni FSD shocks on my C6. I had posted on the forum about squeaking noise after the shocks were installed. Took the car to the dealer today and they found that the Koni FSD shocks were hitting the body of the car. There is a spot right above of all 4 shocks that the rubber bushing stopper on top the shock that seem to bottom up against the car.
Can someone tell me whether this is normal? Also is there any problem of the rubber stopper on top of the shock coming in contact with the car? Thanks
Old Jun 18, 2008 | 08:19 PM
REVAK's Avatar
REVAK
Default Koni's
Did you reuse the original bushings and shields or the koni stuff ? When I installed the koni's on my 06 vert, I decided to reuse all of the original bushings and shields. The stock hardware looked heavier to me. 10,000 miles on them ,no noises or complaints about the shocks.
Old Jun 18, 2008 | 08:30 PM
FUNTRUN's Avatar
FUNTRUN
Default Koni noise
You might want to call tech support at Koni and see what they say.
Old Jun 18, 2008 | 09:16 PM
csun213's Avatar
csun213
I did use the orginal bushing and shields. That was what most of the guys on the forum were doing.
Just wondering if the shock is suppose to travel up and bump against the car?
Old Jun 18, 2008 | 09:17 PM
csun213's Avatar
csun213
I will call Koni tomorrow and see if the shock is suppose to bump up against the car.
Just wondering if anyone else running Koni FSD had noticed a shine right above the shock.
Old Jun 18, 2008 | 09:49 PM
TommyV's Avatar
TommyV
St. Jude Donor '06-'07-'08-'09-'10-'11-'12, '16
No contact on mine.
Old Jun 18, 2008 | 10:18 PM
Tblade's Avatar
Tblade
No issues with mine whatsoever but it did lower the car at least 1/2 inch after the install so I do rub the front piece a bit more often now.
Old Jun 18, 2008 | 10:24 PM
Modshack's Avatar
Modshack
Sounds like you neglected to install the washer between the stepped shaft and the top bushing assembly. If that washer is not there as a stop, the shock body could rise n the assembly and make contact...
Bilstein example:
Old Jun 18, 2008 | 11:21 PM
csun213's Avatar
csun213
Bilstein example:
I believe the washer was installed. Just wondering if anything else can cause this problem. It is hitting on all 4 shocks.
Old Jun 19, 2008 | 12:32 PM
Modshack's Avatar
Modshack
Something is amiss with your installation..
Old Jun 19, 2008 | 04:29 PM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Mine are fine.
Old Jun 19, 2008 | 05:37 PM
csun213's Avatar
csun213
You are right. Took it to a dealer and there is a gap between the shock and the body of the car. It seems that the white plastic piece that is between the shock and bushing fell into the shock.
Will go back to the installer tomorrow and have the shock taken off and re-installed.
Thanks guys, you were right that something is wrong here. Will find out tomorrow.
To Question about Koni FSD shocks
