Pulls to the right after alignment x2
Old Jun 20, 2008 | 05:42 PM
nomo50's Avatar
nomo50
Default Pulls to the right after alignment x2
I lowered my beast on stock bolts, cut the rears. The car tracked perfectly. But, since we are all warned that an alignment is necessary, I got the alignment done. after the alignment the car pulled to the right. Took it back for a redo. still pulls to the right, just not quite as bad. also seems to follow uneven ruts in the road as well.
Any suggestions?
Old Jun 20, 2008 | 06:33 PM
glennhl's Avatar
glennhl
Where did you get the alignment done? Sounds like you have more negative camber on the left front than the right front.
Old Jun 20, 2008 | 06:42 PM
C6400hp's Avatar
C6400hp
From: DFW This user does not support or recommend the product or service displayed in the ad to the right
Any suggestions?
Post the specs from your alignment sheet.
calemasters's Avatar
calemasters
When was the last time the alignment rack was calibrated. Did the tech use the GM alignment specs or some other specs.
Old Jun 21, 2008 | 08:14 AM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
We need more info.
Old Jun 21, 2008 | 08:52 AM
overrev64's Avatar
overrev64
Sounds more like a toe or caster problem.
Old Jun 22, 2008 | 03:47 AM
L454S's Avatar
L454S
Default Caster
Did alignments for many years. Without seeing the spec sheet, sounds like a caster problem. I always added 1/2 degree more caster to the right front wheel to compensate for some road crown.
That is providing the front tires dont have any conicity issues.
To Pulls to the right after alignment x2
