Cartek's LS 3 cam only!
The exhaust restriction does effectively limit the size (i.e. overlap) that you can run. I'd bet a 224/232 114 112 would probably make for a very good cam on stock manifolds. Reasonable DCR and should pull strongly to 6500.
Look up a member 11secondGP. He was doing a cam no headers in his LS3. I think he hit 440 RWHP.
And a "turbo car", well that means they just hooked up a turbo to one of the manifolds, no intercooler, no fuel system mods, no waste gates, just that turbo.
Good luck to the Cartek crew with the project and good luck to Ed's future runs as he realizes the better ET's the car is capable of, as indicated by the trap speeds proving its legit power level.
Off topic, I wish all of you could see the mountain views I have here in Colorado on my vacation. I've never seen this before and feel I was cheated living on the flatlands in America.
1) That either the dyno numbers are false (dyno sensor/correction factor manipulation etc.)
2) That the parts combos weren't the best choices.
3) That the tuning parameters changed were done strictly to make the car look great only on the dyno with too little thought to how it will react on the road/track.
Properly matched parts (cams, heads, springs, gearing etc.) and tuning have always been and always will be Cartek's forte/specialty in making these cars run really fast and reliable regardless of what the dyno sheet says.
But just to give you some real numbers, there have been two LS2 automatic cam only Cartek cars recently that have run strong and dyno'd quite respectably as well.
Superstock 1200's and Tony B4's Cartek cammed LS2 automatics both made in the 433 to 441rwhp range. LS2 motors being slightly smaller with a head design that many consider to be lower flowing and of course automatics eat more rwhp than manuals.
It's would be difficult to pin down an exact number at this time but an LS3 manual car like Anthony's will certainly dyno much higher than that with a similar cam only set up.
I have a house high up in the Rockies that I haven't been to in several years. Enjoy gods country.
We are now at 484/439 with this tune.
Just biding my time
I have the little engine(LS2)that could attitude.
