Directions for Header Install
Old Jun 24, 2008 | 03:24 PM
Bad06vette's Avatar
Bad06vette
Default Directions for Header Install
Anyone know where I can go to get some good step by step directions on the a header install? I am not very mechanically inclined but I think me and a friend or two might give installing headers a try on the vette. I just bought a used set of kooks 1 3/4 and catless x pipe/mids. Trying to decide if I wanna give it a shoot or shell out the 4-500 to get them installed.
Let me know! Thanks!
Also, any suggestions or anything I should know before I attempt this? Thanks!
Old Jun 24, 2008 | 04:23 PM
fastskyline's Avatar
fastskyline
check the FAQ section or try a search. good luck, headers are fairly easy to install
Old Jun 24, 2008 | 04:25 PM
lockman's Avatar
lockman
it's pretty easy I did it last sat. it took about 2 hours total. I just jacked the front and back up you need about 24inches of clearance. you take the plastic covers off then the sparkplugs and wires. then I unbolted the cats from the headers and the x pipe and dropped them out then I unbolted the x pipe and put it aside of course you have to unhook the 02 sensors both sets then unbolt the manifold and they will drop right out the bottom I would recomend having a buddy there to help raise and lower the headers they aren't heave it just makes it easier. I used the GM gasket I wouldn't recomend the gasket that comes with the kit. it may work I just didn't like it. and then put the x pipe and everything back together it's pretty easy.
Old Jun 24, 2008 | 04:29 PM
Bad06vette's Avatar
Bad06vette
I checked and did a search... couldn't find any step by step.
Bad06vette's Avatar
Bad06vette
Thanks for the info! Yeah, I will prob be doing this on jackstands... I would like to use a lift.. but, you work with what you got.
Old Jun 24, 2008 | 04:32 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
Header install is not the toughest DIY job, but when you say you're not mechanically inclined, does that also mean you don't have much in the way of tools? You will need a jack & jack stands to get the exhaust pipes off & then a reasonably good selection of wrenches, ratchets, extensions, sockets, etc for disassembly & installation. You might also contact Kooks directly & ask if they pack an installation guide with their headers....if so, they might be willing to send one to you.
Old Jun 24, 2008 | 04:34 PM
Bad06vette's Avatar
Bad06vette
Mechanically inclined; meaning that I have not done a header install before. I will be doing this with a buddy in his garage... he has an exhausting (no pun intended) amount of tools and jackstands, etc. So, we should be good with tools and everything.
Old Jun 24, 2008 | 05:14 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Feel free to give me a call if you have questions or run into problems and we can try and talk you though it.
609-752-0321
__________________
Home of the Fastest Supercharged C5 8.4 @ 158mph
Home of the Fastest Supercharged IRS GTO 9.0@ 155
Home of the Fastest Supercharged C6 9.7 @ 143mph
Proud Sponsor of the ECS Corvette Challenge
http://www.corvettechallenge.info
609-752-0321
Old Jun 24, 2008 | 05:31 PM
Bad06vette's Avatar
Bad06vette
609-752-0321
Hey, I appreciate that a lot! I will hold you to that.
Old Jun 24, 2008 | 05:33 PM
Cruise-In V Veteran
no problem at all, we are here to help
Old Jun 25, 2008 | 06:26 PM
naschmitz's Avatar
naschmitz
These are the step by step instructions I followed:
http://www.gmhightechperformance.com...ion/index.html
Here are the photos of my install:
http://forums.corvetteforum.com/show....php?t=1896799
It is a fun project.
Old Jun 25, 2008 | 08:07 PM
glennhl's Avatar
glennhl
Good instructions, but I saved some time by taking out the OEM Cats along with the exhaust manifolds while they were still hooked together. You can still wiggle them out and that way you save from busting your knuckles trying to get the 4 cat bolts/nuts off. Also, I actually did mine without taking out the spark plugs, but I did take out the dip stick tube.
Old Jun 25, 2008 | 08:16 PM
Craigster05's Avatar
Craigster05
St. Jude Donor '07-'08-'09-'11-'12
Here's another:
http://www.corvettemagazine.com/2005...kooks-lead.asp
http://forums.corvetteforum.com/show....php?t=1755451
Old Jun 26, 2008 | 04:14 AM
lockman's Avatar
lockman
use an impact wrench keeps from busting knuckles lol
To Directions for Header Install
