C6 Posi Rear?
Old Jun 28, 2008 | 11:46 PM
Gdemoman's Avatar
Gdemoman
Default C6 Posi Rear?
I'm just wondering, is there a way to install a posi unit in a c6 rear? Has this ever been done? Can it be done? I'm under the impression a posi traction rear end would allow BOTH of the rear wheels to grip equally and thus perhaps allow for the car hook up better off the line. Just wondering.... Thanks
Old Jun 29, 2008 | 01:50 AM
Silverspeed's Avatar
Silverspeed
St. Jude Donor '13, '15
If you can only get one wheel to spin in your vette, take it in, cause it's broke. Your car is already posi, a.k.a limited slip. They are the same.
Old Jun 29, 2008 | 08:52 AM
Gdemoman's Avatar
Gdemoman
I can definitely get both tires to spin... My question was more regarding what was my understanding of posi vs. limited slip. Someone correct me if I wrong but, in a limited slip you'll always have more output power to one side over the other (to allow for cornering radius on turns, etc.) in a true posi set-up equal power goes to both wheels.
Old Jun 29, 2008 | 09:10 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Posi-traction is a trade name from Chevy, Ford had Traction-Lok, Chrysler had Sure-Grip, (I might have those names wrong but you get the idea). They are all the same, clutches or cones in the differential to prevent one side from spinning at a substantially greater speed than the other. They apply pressure via clutches or cones to the spider gears on the axles to make them spin the same.
You can buy a ratcheting "detroit locker" rear for true posi but they are bad news on the street, clicking and clunking. You could also weld your spiders but not on a street car.
Your vette has posi, keep the recommended fluid in it. My posi went weak when I switched to Royal Purple and was "peg legging" only one wheel spinning. When I went back to recommended fluid it works great, posi all the time.
Dunno why I typed all that. You can learn all you need to know about posi's here:
http://auto.howstuffworks.com/differential.htm
Old Jun 29, 2008 | 12:17 PM
Gdemoman's Avatar
Gdemoman
Joe G- Thank you, good info...
Old Jun 29, 2008 | 01:20 PM
dennis50nj's Avatar
dennis50nj
you forgot the spool and mini spool trac lock auburn gear and air locker
Old Jun 29, 2008 | 01:29 PM
Braciole's Avatar
Braciole
St. Jude Donor '08
Hey Joe,
Do you have synocromax in your trans?
Im glad I didnt put it in my rear!!
But I do have it in my trans. I didnt notice much
Mike
Old Jun 30, 2008 | 10:17 AM
haljensen's Avatar
haljensen
2 Traction control systems on the C6;
The electronic Traction Control on all 'Vettes that uses the wheel speed sensors of the Anti Lock brakes.
The clutch type limited slip.
Old Jun 30, 2008 | 12:55 PM
Vito.A's Avatar
Vito.A
Joe G did a great job of explaining the different differentials.
On the race cars we use a "spool" instead of a differential. The spool has the ring gear bolted to it and both axles spline directly into each side. It does not have spider gears (differential pinions), axle side gears, or clutches and both axles spin exactly the same amount, but it hates any kind of sharp turns and would be impossible to live with in a street driven car.
Enjoy the limited slip/positraction your car came with.
Old Jun 30, 2008 | 12:59 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Originally Posted by Braciole
Hey Joe,
Mike
Nope, factory fill in both is doing just fine!
Old Jun 30, 2008 | 02:01 PM
Gdemoman's Avatar
Gdemoman
Thanks again Joe G, Vito, and everyone else on clearing this up for me...
Old Jun 30, 2008 | 03:41 PM
todd@rpmtransmissions's Avatar
0todd@rpmtransmissions
Former Vendor
http://www.autotech.com/quaife/index2.htm
Here is a link to the Quaife ATB differentials. Click on the ATB differentials link on the top left. We've installed many of these with great results. They are a great improvement over the factory clutch type differentials. Give TJ a call if you are interested at 800-406-1109.
Todd
To C6 Posi Rear?
