Lowered car, help with raising...
Old Jun 29, 2008 | 11:13 AM
huggerorangss's Avatar
huggerorangss
Default Lowered car, help with raising...
Thanks for everyones help in advance!
I have a 2006 C6 coupe Vette. I lowered the car as much as it can go in the front without cutting the bushings, and lowered the car in the rear as far as it could go and did cut the bushings. Well, my predicament is that now that I have 325's on 11 inch rims in the back, the tire will rub the lip on the fender. I want to raise the car back up, but should I get new bolts with a new bushing, if so does anyone know the part number, OR, do you guys think it would be okay to raise it back up without getting a new bolt with the bushing? And lastly, if I just raise the back up about a quarter of an inch, do you think an alignment is needed?
Thanks again!
Chris
Old Jun 29, 2008 | 10:12 PM
corvette dave's Avatar
corvette dave
If you cut off all of the rubber bushing you should put new adjusters on. If you still have some rubber bushing left then just raise it.
There is absolutely no way anyone can tell you if you need an alignment after raising the car 1/4". It depends where the alignment settings are before you raise it. There may be enough room to make a ride height change and still be in spec. There may not.
No way to tell without checking the alignment.
Old Jun 29, 2008 | 10:21 PM
huggerorangss
Thanks...I'm just going to go to the dealer tomorrow and get new bolts and probably end up getting an alignment.
Old Jun 29, 2008 | 10:30 PM
corvette dave
As far as I know you can't get new bolts at the dealer.
Just a new spring with bolts in it.
Old Jun 30, 2008 | 09:44 PM
huggerorangss
You are correct, so as I found out today...
Any suggestions anyone?
Old Jun 30, 2008 | 10:52 PM
corvette dave
Hugger,
Try this company:
http://hardbarusa.com/hardbar/produc...products_id=48
The adjusters are shown in the upper right corner.
I have never purchased anything from them but I have been impressed with the looks of their products.
Gary Hoffman is the owner, I think. He is a supporting vendor.
Old Jul 2, 2008 | 09:33 PM
huggerorangss
Thanks DAve,
I think I might give them a try.
I appreciate the help buddy!
Old Jul 2, 2008 | 10:53 PM
HorsePower Junkie's Avatar
HorsePower Junkie
St. Jude Donor '20-'21-'22-'23
Unless you have no rubber at all left on the bolts after you cut the bushings there would not be any need to replace the bolts...meaning that if there is still some rubber left on the bolts and it's not "metal to metal" then just raise it back up to where you want it.
Alignment will change, and as expensive as the tires are I would get it aligned.
Old Jul 2, 2008 | 11:44 PM
corvette dave
This was covered in an earlier post.
I am assuming the bushings have no rubber.
To Lowered car, help with raising...
