I put a ZO6 exhaust on my C6 and of course it didnt come with the stock vacuum stuff to operates the flaps. Aside from wiring them shut, it there a different kit other than buying the stock vacuum set up to operate the flaps? I thought i seen something on here a few month back, but i couldnt find it using the search button.
I did the same with my C6. I took the vacuum chambers off, and replaced it with an althread thumb screw with two lock nuts. so you can leave it open or closed, but you manually have to loosen the linkage to change it. There wasn't much drone, so I left mine full open. but I am looking at the Mild to Wild set up as well. just wish there was a better price for it.
I used Nakidparts NPP in a box kit. Installation was unbelievably simple and fast even for an idiot like me. Now I just press a button on a remote, two are included in the kit, to open or close the valves. Great product!
I Did The Same Install Of Z06 Exhaust And Hadnt Seen The Nakidparts "npp In A Box" Setup So I Made One Myself After A Couple Of Hours Of Troubleshooting And It Only Cost Me About 85 Dollars And Four Install-troubleshoot Time.
wow, I am all for saving a couple of hundred bucks. can you post pics ,parts list, or instructions on how you did it?:
