Slight flicker of lights
Old Jul 3, 2008 | 08:09 PM
RedTornado's Avatar
RedTornado
Default Slight flicker of lights
I have on 05 C6 coupe. I recently noticed that at idle, the tail lights and floor courtesy lights have a slight irregular flicker. Nothing in the front lights. As soon as you come up off idle, it stops. Any suggestions?
Old Jul 3, 2008 | 09:54 PM
danl72's Avatar
danl72
Could be your battery is going bye bye.
Old Jul 4, 2008 | 11:50 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Does it happen at all times or do you notice it as the car is warming up and getting to operating temperature?
My Camaro (LS1), when it was stock, many years ago, would flicker the lights as you described when the AIR system was cycling during engine warm up. The AIR pump would be going on an off causing the lights to flicker at idle. When the CATS would light off and start functioning, the AIR pump would stop operating and the flickering would stop.
Elmer
Old Jul 4, 2008 | 02:56 PM
chazc6's Avatar
chazc6
St. Jude Donor '10
Default Check your battery
How old is the battery in your car? My head lights did the same thing a few weeks before it went bad. It may be time for a new battery.
Old Jul 5, 2008 | 06:48 PM
RedTornado's Avatar
RedTornado
Naw, the battery is about 6 months old. Also, ran a diagnostic thru the OnStar, and it didn't indicate any codes or problems. A few months ago, I did swap out the rear third light, the one with a row of LEDs. I wondering if those may pulsate, and might be causing the flicker.
Old Jul 6, 2008 | 12:16 AM
bosco 08's Avatar
bosco 08
bad ground
To Slight flicker of lights
