Where to get smooth coupler???
Old Jul 8, 2008 | 12:26 PM
dsp300c's Avatar
dsp300c
Default Where to get smooth coupler???
In my other post I installed the FAST 90 on my car. I am looking for a smooth coupler I can put between my Honker and TB. Where can I get one? All I find are ones for the C5.
Thanks,
Andrew
Old Jul 8, 2008 | 12:30 PM
silvr07's Avatar
silvr07
Andrew -
Try Silicon Intakes
www.siliconeintakes.com
Steve
Old Jul 8, 2008 | 12:36 PM
dsp300c's Avatar
dsp300c
Thanks. That is perfect. Now I have to figure what size I need unless somebody already knows.
Old Jul 8, 2008 | 12:40 PM
dennis50nj's Avatar
dennis50nj
igot my coupler at pep boys smooth black 3.75x4.00 its in the import section
Old Jul 8, 2008 | 12:49 PM
dsp300c's Avatar
dsp300c
Thanks for all the info. This forum is perfect.
Old Jul 8, 2008 | 01:16 PM
dsp300c's Avatar
dsp300c
Went and looked at my accordian style coupler. There is a sensor in it. If I replace it with a smooth coupler, how and where do I put that sensor?
Old Jul 8, 2008 | 03:47 PM
dsp300c's Avatar
dsp300c
bump
Old Jul 8, 2008 | 03:50 PM
not08crmanymore's Avatar
not08crmanymore
cut a hole and put it in the same place,no?
Also,home depot/loewes probably has them too.
Old Jul 8, 2008 | 04:04 PM
dsp300c's Avatar
dsp300c
maybe...thought i could do that but wasn't sure...wanted to see if anyone else had done that before i did and messed it up...haha...
Old Jul 8, 2008 | 04:05 PM
dennis50nj's Avatar
dennis50nj
just drill a small hole and push it in you can wipe it with a little oil with a q tip
Old Jul 8, 2008 | 04:15 PM
dsp300c's Avatar
dsp300c
guess i will attempt it and see what happens...wish me luck
Old Jul 8, 2008 | 04:36 PM
not08crmanymore
Let me know how it turns out!I haven't done it yet!!
Old Jul 8, 2008 | 04:39 PM
Ben Diss's Avatar
Ben Diss
Le Mans Master<br><img src="/forums/images/ranks/5k-6k.gif" border="0">
St. Jude Donor '08-'09
What's the gain from this mod? Is it cosmetic only?
Old Jul 8, 2008 | 04:40 PM
dsp300c's Avatar
dsp300c
i will be the guinea pig i guess...hope to post up the results in a few days if i can't find a coupler with the sensor already in it
Old Jul 8, 2008 | 09:38 PM
nwc6's Avatar
nwc6
The accordion fitting is for the PCV system. It is not a sensor. Just pull the barb fitting out, poke a hole the smooth coupler and stick it in..
To Where to get smooth coupler???
