Sway Bar Swap Trouble
Old Jul 13, 2008 | 12:24 PM
WGO's Avatar
WGO
Default Sway Bar Swap Trouble
I am swapping out the sway bars on my '08 with F55 for Z51 sway bars.
Started with the rear and have the Z51 sway bar installed.
During initial torquing, my Torx bit broke off in the passenger side link bolt. It broke off inside the bolt so I can't get a grip on it to pull it out.
I need ideas on how to get it out of there.
Beyond my immediate problem, a few more questions.
1. The bit I was using doesn't have a size stamped on it. What size is it (so I can get another)?
2. I was using torque values that I got from this forum. If anybody has a Helms manual, would you please post the values as a double check.
Thanks,
Bill
Old Jul 13, 2008 | 01:20 PM
patton's Avatar
patton
St. Jude Donor '09
get a very good sharp center punch [not where ya bought your torx socket] and start working over the broken bit NOT THE STUD it should work free .dont kill it with heavy hammer blows. get a GOOD set of torx bits
Old Jul 13, 2008 | 04:10 PM
DennyBlueC6's Avatar
DennyBlueC6
T-40 torx, 72N-m 53 lb ft
Old Jul 13, 2008 | 04:50 PM
vetracer's Avatar
vetracer
going strictly from memory I think the back of the link has flat spots where you could possibly slide a very thin wrench in there to keep the stud from turning - its worth a look anyway...
The rear lowers are a pain to get at - its best to remove the uppers where they attach to the bar then remove the bar. If you need to take off the links (which in your case you shouldn't) go back and undo the lowers (at the control arm) once the bar is out of the way. when reinstalling put the links on the lower control arm first then install the bar.
Old Jul 13, 2008 | 05:21 PM
SnowyATX's Avatar
SnowyATX
I agree on the flat spots!
I snapped two torx bits doing mine until I used the wrench method. I just tapped on the nut (with wrench or whatever) and end link and the broken tip finally just fell out. If you use the torx bit I think its better to tighten the nut not the stud but I could be dreaming.
Old Jul 13, 2008 | 06:36 PM
danl72's Avatar
danl72
Old Jul 13, 2008 | 07:22 PM
mcwire's Avatar
mcwire
-- You're not dreaming. Spinning the stud, may loosen it, in the socket, and result in a clunking noise. Unfortunately, I'm speaking from, a not so good, experience. -- --
Old Jul 13, 2008 | 07:50 PM
CMY SIX's Avatar
CMY SIX
if you're going to work on your car get a set of manuals along with a decent set of tools! IMHO
Old Jul 13, 2008 | 09:07 PM
timd38's Avatar
timd38
I used a "tappet" wrench. Very thin to get between the boot and the socket. Don't remember the size.
Old Jul 15, 2008 | 04:19 PM
WGO's Avatar
WGO
I can't agree more.
Unfortunately my impatience got the best of me while the Helms Manuals were in the mail. The stabilizer bar swap looked easy. Until I did it in what looked like the obvious way. Dumb, dumb, dumb.
Just got the manuals and read about using a wrench to hold the stud from turning. Then why the heck is there a Torx socket in the end of the stud? Maybe it is okay for loosening only.
The Torx bit I broke was a Sears Craftsman brand. I have never had a problem with their tools unless I used a driver that was longer than standard. I this case, my 3/8" drive torque wrench is about a foot longer than a standard 3/8" ratchet wrench. And I was using it to turn the stud with the Torx bit while holding the nut with a wrench. Like I said, it looked obvious.
At least give me credit for having torque wrenches. A couple of them actually, to cover different ranges. Still don't have one in inch-pounds though.
My tool set is all Craftsman, huge stacking chest and toolbox with at least two of everything. And a few smaller toolboxes to hold the overflow.
What do you consider to be a better brand of tools?
Bill
Old Jul 15, 2008 | 04:24 PM
johnodrake's Avatar
johnodrake
Moderator
MATCO or Snap On - but I use Craftsman too
Old Jul 15, 2008 | 04:34 PM
WGO's Avatar
WGO
Anybody remember the size?
Or if it was metric or so-called standard?
I'll order a set if I know which flavor to choose.
Bill
Old Jul 16, 2008 | 12:40 PM
jim2092's Avatar
jim2092
Veteran: Marine Corps
St. Jude Donor '08
Default 18mm
First of all, do not turn the link studs. If you do or have turned them, they may be damaged and make a clunking noise during low speed operation. Turn the nuts with a metric wrench or socket while holding the studs from turning with an 18 mm open end wrench.
Old Jul 16, 2008 | 01:03 PM
CMY SIX's Avatar
CMY SIX
I do give you credit for DIY, and I have to admit I would have recommended craftsman and still do, if you can get the piece of bit loose with the punch you might try a magnet to lift it out. they use the torx because it's the same everywhere. neithier metric or sae
Old Jul 16, 2008 | 01:36 PM
danl72's Avatar
danl72
I made sure I held it in place.
To Sway Bar Swap Trouble
