Engine Ground Map?
Old Jul 14, 2008 | 11:53 AM
NavyC4S's Avatar
NavyC4S
St. Jude Donor '09
Default Engine Ground Map?
Does anyone have a map of the engine grounds. I still have the SCS error and I have been informed that it could be a loose engine ground.
Any help appreciated.
Old Jul 14, 2008 | 01:21 PM
knkali's Avatar
knkali
how are the volts doing? If the car is charging and you have a message only call Tracy at RevExtreme a forum vendor. He has a modded alt that might be the trick. Otherwise welcome to my hell with this too.
Old Jul 14, 2008 | 07:49 PM
mike12345's Avatar
mike12345
Hope this helps
Check out this earlier thread:
http://forums.corvetteforum.com/show....php?t=1974842
Old Jul 14, 2008 | 08:23 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Working in conjunction with that excellent ground map, use this to see exactly what is tied into those ground connections:
http://www.ls2.com/forums/showthread...hreadid=648556
Elmer
Old Jul 15, 2008 | 06:55 PM
NavyC4S's Avatar
NavyC4S
St. Jude Donor '09
The car charges Ok...I get 11.8 at idle and more like 14.5 at speed with an overdriven 145 amp alternator... help?
Old Jul 15, 2008 | 09:22 PM
TLewis4095's Avatar
TLewis4095
You need a steady 12.3-12.7 at idle to not trigger the warning. The 14.5 at speed is more than adequate.
Old Jul 16, 2008 | 10:36 AM
NavyC4S's Avatar
NavyC4S
St. Jude Donor '09
Correct, I get low voltage at idle...I think I may just have to have e pulley taken off.
To Engine Ground Map?
