Which CAI is best
Old Jul 17, 2008 | 09:11 AM
chucky7's Avatar
chucky7
Default Which CAI is best
Don't flame me for this thread, just trying to figure out what afer market CAI will give me the best performance while keeping the temps down. Have a HAlltech on there now and cut shroud.
Charlie
Old Jul 17, 2008 | 09:12 AM
xstang's Avatar
xstang
Vararam
Old Jul 17, 2008 | 09:27 AM
dennis50nj's Avatar
dennis50nj
now you know, hands down Vararam is the best. and proven the fastest by being on the fastest bolt/on c6, if you want cooler water temps get a 160 stat and ewp with cartek fan module
Old Jul 17, 2008 | 09:42 AM
BearZ06's Avatar
BearZ06
St. Jude Donor '09 thru '17,'22 thru '26
The Halltech is the best without cooling or water ingestion concerns-keep it!
Old Jul 17, 2008 | 09:48 AM
xstang's Avatar
xstang
Is the Halltech an open element filter? Any system that doesn't seperate the filter from the engine bay is bad news... The IATs will be through the roof on hotter days... I logged my friends Killer Bee and he sees 120-140 Iats on a regular basis here in tx.. You need to make sure the filter isn't exposed. This gets worse if you have headers because the underhood temps increase. If the Halltech has something over the filter, then it would be ok, but not as good as the Vararam, Honker, etc.....
I would rate the CAIs like this...
Vararam
LPE, Honker, Vortex
Any open air element
Old Jul 17, 2008 | 10:19 AM
1cheesecake's Avatar
1cheesecake
Not sure if this has been covered here before....
Try the search feature...and see who is complaining about what...
Personal I run the Callaway Honker and am very happy with it
Old Jul 17, 2008 | 10:30 AM
BearZ06's Avatar
BearZ06
Yes with the new Halltech shroud the intake is seperated.
Old Jul 17, 2008 | 10:34 AM
xstang's Avatar
xstang
That makes a huge difference...
Old Jul 17, 2008 | 10:43 AM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
All are an inprovement over the stock setup. I like the Vararam since it a cold air system. I noticed a nice improvement and coupled with Nakid Parts Shroud Cover, it looks stock. I don't have any 1/4 mile times but the SOTP meter says more power It fit perfectly and cutting the stock shroud is challenging but to be true CAI, it has to be done.
Old Jul 17, 2008 | 12:07 PM
LS1LT1's Avatar
LS1LT1
There's that one that begins with a 'V', uhh not sure what it's called, it like 'Rams' the air in there a bit, it's on the tip of my tongue, what was that damn name now.
Oh yeah, it's called the VARARAM!
Old Jul 17, 2008 | 02:10 PM
chsmith112's Avatar
chsmith112
Was that really necessary? hahaha
I am going to be getting the honker, it will be here on Monday
Old Jul 17, 2008 | 02:19 PM
Mike02z's Avatar
Mike02z
The Vararam is generally regarded has giving the most HP. it is also generally know as the poorest build quality with the crapiest instructions. There are also people who have had the seal fail between the 2 halves of the filter cover and one report of the spacer becoming seperated and allowing dirt directly into the engine. Poor fit is another issue people have been complaining about.
If I were you I'd keep the intake you have.
Old Jul 17, 2008 | 02:25 PM
tama2112's Avatar
tama2112
Are there any good ones that don't require "cutting"?
Old Jul 17, 2008 | 03:03 PM
Topless's Avatar
Topless
Cruise-In IV Veteran
St. Jude '03-'04-'05-'06-'07-'08
The search function is your friend. There are more than enough threads about CAIs available.
To Which CAI is best
