Slicks and wheels
Old Jul 21, 2008 | 12:56 AM
dsp300c's Avatar
dsp300c
Default Slicks and wheels
Currently am using 18" C6 wheels mounted with BFG DR's.
I was looking into some skinnies up front and 17" Welds or something similar in the back with some MT Slicks or ET Streets.
What size, bolt pattern, offset, etc would I need for the wheels?
What tire size would I need for them also?
Thanks,
Andrew
Old Jul 21, 2008 | 01:34 AM
LS1LT1's Avatar
LS1LT1
I don't think there are any of the lightweight (Pro Stars, Draglites etc.) Welds made in 17", at least not ones in the bolt pattern and widths needed to fit on a C6.
You might have to go with a CCW Classic or some form of Corvette factory/OEM or aftermarket/replica rims.
Bolt pattern is 5x4.75.
The standard rear offset is 79mm but you can stray a little from that if need be.
There is only one Mickey Thompson DOT legal slick in 17", the 26x11.5x17 ET Street bias ply.
