Quick question
In the process of doing this swap, I had bought the LS1 o-ring seal kit (16 o-rings) to get the lower 8 o-rings necessary for the intake base. My question is: Are the upper and lower injector o-rings on the LS1 injectors interchangable? If not, then does anyone have a part number on the upper LS2 injector o-ring? It's a blue o-ring, the LS2 lower o-ring was red, and the LS1 o-ring is brown.
I could measure them, but sometimes the correct size is not the only criteria. Sometimes the material is different.
Any help would be appreciated, as my wife wants to use the car this weekend for a high school reunion.
