headers fit ls2 and ls3
Old Jul 21, 2008 | 08:47 AM
s ladd's Avatar
s ladd
Default headers fit ls2 and ls3
I know this has probably been mentioned but I have searched and have not found an answer yet. Do headers meant for an LS2 fit an LS3? I read somewhere about the ports on the LS3 being shaped like a "D". Is this going to be an issue with LS2 headers?
Thanks,
Shaun
Old Jul 21, 2008 | 08:50 AM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
same. same header will bolt up to both 243 and l92 heads..
-carl
Old Jul 21, 2008 | 08:52 AM
s ladd's Avatar
s ladd
awesome.. Thanks for the quick reply.
Old Jul 21, 2008 | 07:34 PM
Bobby @ LG Motorsports's Avatar
0Bobby @ LG Motorsports
Former Vendor
LS7 is close, depending on the header. Ours are close, and we modify C6 or C5 headers if a customer is planning on or upgraded to LS7 heads.
LS1/2 heads to LS3 heads is not enough make a difference with our header, even though the port height is higher on the LS3/L92s.
Old Jul 22, 2008 | 01:04 PM
AndrewZPSU's Avatar
AndrewZPSU
Also, the LS7 headers fit on the LS3 for obvious reasons (same heads). You just need a different X-pipe if connecting to the stock or 2.5 inch exhaust.
But no issues putting LS2 headers on the LS3.
Old Jul 22, 2008 | 03:42 PM
Louis @ LG Motorsports's Avatar
0Louis @ LG Motorsports
Former Vendor
They will fit, bolt up physically yes, but the port height on an LS7 compared to that of an LS3 is not the same. There is a big enough difference that the headers need to be modified.
To headers fit ls2 and ls3
