Intake manifold swap
Old Jul 21, 2008 | 09:18 PM
MARSC6's Avatar
MARSC6
Default Intake manifold swap
I have a new ls2 intake on the way from Corvette Pilot and need some install advise.
Will I need any new seals or can I reuse what I have?
Also what should the bolts be torqued to?
Any suggestions to make the swap easier?
Old Jul 21, 2008 | 09:44 PM
BearZ06's Avatar
BearZ06
St. Jude Donor '09 thru '17,'22 thru '26
http://www.ls2portworks.com/Installation.html
Old Jul 21, 2008 | 09:49 PM
corvette pilot's Avatar
0corvette pilot
Former Vendor
I just did a swap for a customer a couple weeks ago, and I used those instructions.
A couple places I did things different were
-disconnecting the master cylinder vacuum line, I disconnected it at the master cylinder and worked it out of the car
-removing the throttle body. I left it on the manifold and swapped it over on the workbench.
they seemed to make it a little easier.
Old Jul 21, 2008 | 09:53 PM
BearZ06's Avatar
BearZ06
I agree on the brake booster hose.
Old Jul 21, 2008 | 10:11 PM
MARSC6's Avatar
MARSC6
Seems easy enough.
Thank you all for the help.
To Intake manifold swap
