Rear axle ratio = Confused??
Old Jul 24, 2008 | 08:02 AM
beepster's Avatar
beepster
Default Rear axle ratio = Confused??
I have a '09 on order w/ F55 suspension. I opted for the 2.73 performance rear axle ratio because I felt it would make the car a little quicker off the line (equal to Z51?). Now I'm reading about the guys who go w/ the 4:11 gears w/ great results. Is the 2.73 option a waste of money ($395)?? Opinions and thoughts appreciated!!
Old Jul 24, 2008 | 08:15 AM
Bob Walker's Avatar
Bob Walker
Hi Vette Guy, a 4.11 will get you off the line quicker but you will be doing higher revs (and chewing more juice) at cruising speed. The 2.73 will be a little slower off the line but, depending on tire sizes etc. you might be doing only (say) 2,000 revs at cruising speed. Depends on what you want, quick acceleration and low economy or a bit slower ofthe line and better fuel consumption.
Old Jul 24, 2008 | 08:25 AM
LSCHLEM's Avatar
LSCHLEM
St. Jude Donor '08-'09-'10
Will the car your getting be an automatic or man ? The 2.73 seems awfully high.
Old Jul 24, 2008 | 08:28 AM
CamaroCane's Avatar
CamaroCane
Well im sorry to say if you opted for the 2.73 based on acceleration it was a waste of money. However there are pros and cons to everything.
Old Jul 24, 2008 | 09:10 AM
beepster's Avatar
beepster
Thanx for the thoughts so far...the car on order is an A6. What is the advantage of the optional 2.73 ratio?
Old Jul 24, 2008 | 09:17 AM
haljensen's Avatar
haljensen
This seems to come up everyday. The A6 w/optional 2:73 is a LOWER first gear than the M6 Z51 w/ a 3:42. Look at the overall ratio, not just rear gears. ie; first gear X final drive, not just final drive.
Old Jul 24, 2008 | 09:24 AM
Braumeister's Avatar
Braumeister
You made a good choice, at least take delivery and try it, I luv my 08.2:73,a6...Pete
Old Jul 24, 2008 | 10:28 AM
azvetters's Avatar
azvetters
[QUOTE Is the 2.73 option a waste of money ($395)?? Opinions and thoughts appreciated!![/QUOTE]
Look at the big picture?????best bang for $395,
read just what you get W/Z51"its not just 2.73"
there's a list of options.
Old Jul 24, 2008 | 10:29 AM
carlrx7's Avatar
carlrx7
the 6mt guys go with 4.10's and the a6's go with 3.42's
-carl
Old Jul 24, 2008 | 11:23 AM
overrev64's Avatar
overrev64
All manual cars come with 3.42 ratio standard. No other ratio is available for stick cars.
Old Jul 24, 2008 | 11:34 AM
Ragtop 99's Avatar
Ragtop 99
If you plan to leave the car alone, getting the 2.73s was a good choice. If you plan to modify the car, going to aftermarket 3.15 or 3.42 will provide more performance than the 2.73s. If you are going to switch, paying for the 2.73s is a waste of money so see if you can cancel it.
Old Jul 24, 2008 | 12:05 PM
LS1LT1's Avatar
LS1LT1
I think when the original poster made the statement below
he was reading about manual cars, not automatics.
VERY FEW people would ever put 4.11s (aka: 4.10s) in an A6 car.
3.15s or 3.42s are the more preferable aftermarket choices for the A6 transmissioned cars...those factory optional 2.73s, though still not nearly as exciting as the aftermarket choices, are at least a decent step in the right direction over the standard 2.56s.
Old Jul 24, 2008 | 02:21 PM
haljensen's Avatar
haljensen
-carl
Rough aproximate numbers;
140,000 'Vettes 05, 06, 07, 08 combined
60% Auto's = 98,000 Auto 'Vettes
MAYBE 2,000 autos w/aftermarket gears in 4 years production.
MAYBE 50 of those with 3:42 gears.
Not an overwhelming number.
Old Jul 24, 2008 | 04:02 PM
C6NRED's Avatar
C6NRED
Do NOT go deeper than the 3.42's with the A6.......you won't have any traction anyway with those gears, and your highway RPM's will be up 500 or 600 RPM......that kind of RPM's on the freeway completely changes the character of the car -- from nice and relaxed to kind of frenetic sounding --- especially if you go with an aftermarket exhuast..
I had 3.73's with my A4 C5, and after driving it around for awhile, I just hated how it changed the car........kinda fun off the line (the torque with those gears would even completely overcome the traction control programming), but for anything else? I'd never do it again............I also lost about 5 or 6 MPG on the freeway --- from 29-30 to 23 to 25.....not worth it with today's gas prices!!!!
Old Jul 24, 2008 | 04:09 PM
LS1LT1's Avatar
LS1LT1
Yeah? That surprises me, with an A4 trans (be it a C5 or even a 2005 C6) I would think that 3.73s are the perfect rear axle ratio for most performance applications.
I do agree that anything higher than a 3.42 gear in the A6 trans might be bordering on unstreetable for most owners.
Old Jul 24, 2008 | 05:08 PM
pettvette's Avatar
pettvette
CI 5-6-7-8-9-10-11 Vet
At 2000 rpm in 4th gear (1.15 to 1) on the A6 the MPH difference is less than 3 mph.....53.94 / 51.17 mph using 27 inches as the tire height.
At 2000 rpm in 6th gear (.67 to 1) the mph difference is 4.75 mph 92.58/87.83 mph (higher mph on the 2.59 gear car)
You should have a very slight acceleration increase with the 2.73 gears(ie 0-60mph)
You could also see a very slight drop in mpg's with the 2.73's
Old Jul 24, 2008 | 05:13 PM
pettvette's Avatar
pettvette
A6 Transmission Gear Ratios
First gear..... 4.02
Second gear. 2.36
Third gear.... 1.53
Fourth gear...1.15
Fifth gear .....0.85
Sixth gear ....0.67
To Rear axle ratio = Confused??
Old Jul 24, 2008 | 07:51 PM
vettesweetnos's Avatar
vettesweetnos
I have an o8 a6 with the 2.73. It is easily worth the $395 since it costs a lot more if you have it done later on, of course you can go a little bigger then. But if you plan to track the car and mod it then do not do the upgrade and do 3.15s later. If you do not plan on drag racing or anything then just get the GU2 option, definitely worth it. Fuel mileage from stock 2.56 axle is 16/26 and with the 2.73 my sticker says 15/25. I plan on a cam, headers, cai, exhaust & tune with my 2.73. No rear upgrade for me as my car will never be tracked.
Old Jul 24, 2008 | 08:02 PM
danl72's Avatar
danl72
I think it is worth it. It will be quicker off the line than stock.
Old Jul 24, 2008 | 11:19 PM
Vette_DD's Avatar
Vette_DD
Look especially at the second chart below, which enters rear axle ratio into the equation.
--GEAR------Mode--or--Option
------------Z06---Std 6-spd---Z51 6-spd--6-spd Auto---4-spd Auto
--1st-------2.66----2.66--------2.97-------4.03---------3.06
--2nd-------1.78----1.78--------2.07-------2.36---------1.63
--3rd-------1.30----1.30--------1.43-------1.53---------1.00
--4th-------1.00----1.00--------1.00-------1.15---------0.70
--5th-------0.74----0.74--------0.71-------0.85
--6th-------0.50----0.50--------0.57-------0.67
Rev---------2.90----2.90--------3.28-------3.06---------2.29
Axle Ratio--3.42----3.42--------3.42----2.56(or 2.73)--2.73(or 3.15)
Gear Ratio times Rear Axle Ratio
------------Z06---Std 6-spd---Z51 6-spd----6-spd Auto-------4-spd Auto
--1st-------9.10----9.10-------10.16-----10.32 or 11.00----8.35 or 9.64
--2nd-------6.09----6.09--------7.08------6.04 or 6.44-----4.45 or 5.13
--3rd-------4.45----4.45--------4.89------3.92 or 4.18-----2.73 or 3.15
--4th-------3.42----3.42--------3.42------2.94 or 3.14-----1.91 or 2.21
--5th-------2.53----2.53--------2.43------2.18 or 2.32
--6th-------1.71----1.71--------1.95------1.72 or 1.83
Rev---------9.92----9.92-------11.22------7.83 or 8.35-----6.25 or 7.21
