OBD code - P1825
Old Jul 31, 2008 | 10:43 PM
wratran's Avatar
wratran
Default OBD code - P1825
Can someone help me with this diagnostic code? I cleared it with the scanner. But should be i be worry? and how do i fix it?
P1825
Internal Mode Switch-Invalid Range
Old Jul 31, 2008 | 11:01 PM
patton's Avatar
patton
St. Jude Donor '09
it refers to your tranny,how is it shifting. you will need a scan tool not a code reader
Old Jul 31, 2008 | 11:36 PM
wratran's Avatar
wratran
it shift ok....
the check engine light hasnt came back.
Old Aug 1, 2008 | 10:17 AM
patton's Avatar
patton
St. Jude Donor '09
first thing to check is linkage
Old Aug 1, 2008 | 09:39 PM
corvettedoctor's Avatar
corvettedoctor
HI:
Try this I had a few Corvettes with this problem. Remove the wiring connector on the right rear of the transmission and reinstall. Sometimes the connection can be weak. Be careful the connector has a lock then twist.
Check the number one fuse under the hood or it might be number 3 fuse for connection I can't remember which right now. Which ever says TCM.
Chris
Old Aug 2, 2008 | 07:49 PM
wratran's Avatar
wratran
thanks
To OBD code - P1825
