When To Change Diff. Fluid
Old Aug 3, 2008 | 06:51 PM
38 Years Later's Avatar
38 Years Later
Default When To Change Diff. Fluid
My Clutch Pack was replaced aurond 5200 miles ago and I have no issues as of yet (Knocking on Wood and Crossing Fingers) with the Diff. Rattling and Clunking. I want to know when and if should the fluid be changed and is it like doin an oil change after so many miles.
Old Aug 4, 2008 | 01:46 AM
38 Years Later
No Help Here??
Old Aug 4, 2008 | 04:33 PM
JRHAWK9's Avatar
JRHAWK9
I am in the process of changing both my tranny and rear end fluids with only 1,300 miles on the car. I will be going with RP Synchromax in the tranny and RP Max Gear 75w90 in the rear. I just wanted to get the factory "breakin" fluid out. I would say do whatever you think and makes you feel better. I seriously doubt you will hurt anything leaving it in, however, you won't hurt anything by changing it either
Old Aug 4, 2008 | 07:45 PM
Braumeister's Avatar
Braumeister
I changed mine at 10k with Amsoil Severe Gear 75w-90 and 1 bottle GM Posi-Lube and all is quiet.
Old Aug 4, 2008 | 07:57 PM
*FAÇADE*'s Avatar
*FAÇADE*
PHOTOSHOP SPECIALIST
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
There is an updated TSB on this condition that utilizes the new DEXRON® LS gear oil, P/N 88862624.
Check it out:
http://forums.corvetteforum.com/1568036286-post3.html
Old Aug 4, 2008 | 07:58 PM
*FAÇADE*'s Avatar
*FAÇADE*
The DEXRON LS GEAR OIL 75W-90 (PART NO. 88862624) can be purchased from Gene Culley (GMPartsHouse.com) at this link:
http://www.trademotion.com/partlocat...&siteid=214638
To When To Change Diff. Fluid
