I heard the rear ends are weak especially on the 05-07's. Can you just change the ring and pinon out or do you have to rebuild the who differential with stouter parts?
I can see this being a problem with the lower ratio'd transmission of my Z51 set up. A car I had back in the early 70's had 410's and it was real quick around town.
For a mod, I figured it would be a good one for the Vette
not sure...i know what 75mph was b/c i checked it before and after the install...i can see what 85mph is and let ya know unless someone else can say it before i do...i would assume 2,500 or so
2500 in 6th at 85 would be a lot better than stock which would probably be under 1K!!
The math is not that tough. Divide the indicated speed at a particular RPM by 4.10. Multiply the results by 3.42. That will be your actual speed at that particular RPM with the new rear.
" Motorhead whats your price for flight " I was getting 33mpg hwy then I switched to 4.10. I lost about 1 mpg. A small price to pay for
all that performance. at 68 mph I was at 1500 rpm and that went to 1750 after 4.10. Standard corvette not z51.
How about "GEEKSTER" , havent used that one yet. BTW I will be posting a 4.10 + FAST VID very soon. Cant overemphasize how much
the 4.10 did for me for the small cost of 1 MPG HWY.
ill be going with 3.90's w/ my z51 for the sake of ever getting into the 10's and not having to shift into 5th or revving the **** outta the motor.
to sample your future mileage, drive down the highway, set cruise in 6th, then note mpg, then shift into 5th re-engauge cruise, and it will be about 1-2 mpg lower.
I love the 410s as well on my base tranny. I couldnt believe the difference they made. For the gentleman that asked what the rpms are at 85, im seeing about 2250 on mine.
