Window tinting with window indexing?
Old Aug 7, 2008 | 08:47 AM
dmaxcamss's Avatar
dmaxcamss
Default Window tinting with window indexing?
When windows are tinted, it's standard practice that you don't roll the windows down for a couple of days.
My question is, the C6s have window indexing, which the window slightly rolls down when you open the door, then rolls up for a tight seal when you close the door. Is this going to be a problem when I go to tint my windows?
Old Aug 7, 2008 | 08:58 AM
ken-rx's Avatar
ken-rx
No problem as long as the tint is below the bottom weather strip. The little bit of movement should have no effect. I had the same concern but it was fine.
Old Aug 7, 2008 | 09:27 AM
JLargo's Avatar
JLargo
The tinter should use a heat gun on the bottom to help dry it as well.
Old Aug 7, 2008 | 09:42 AM
Noel@AutoBuffs's Avatar
Noel@AutoBuffs
Former Vendor
St. Jude Donor '09
A good window tinter knows how to handle this and is no big deal. It's all in the heat to lock in the film.
To Window tinting with window indexing?
