Npp Question ??
I have 2005 c6 Z51 without Npp option and I'm thinking to install the Npp Fuision Cat back, my question is can i install it in a non Npp optioned car ??? if yes is it easy to install it ??
Its a fairly straight forward install to do the Fusion retro bi-mode system install.
I have installed 5 of them and now can do the whole thing from car going on jack to finished in 3 hours.
I have B&B Fusion retro C6 systems in stock for a killer deal too so if your in the market shoot me a PM and I'll send you a quote.
BenSunset Orange Creations
NPP in the box (self contained system to run NPP on any C6) installed in 10 minutes, the guys at his shop were blown away that a car could sound like this. Craig set it to start up with the flaps closed (a simple flip of the switch and you can change it to start open) but when he opened them and hit the gas while I was setting up the camera, I almost went deaf, thanks Craig.
Here is a video I did with my still camera (so it's not great), will take time to load (I can not emphasize enough that you need to turn up the volume and you need a good speaker system (with bass) or a good set of headphones). I have the bose II on my PC and my cabinets shake in the wild mode.
Notice how the inner flaps open and close
Play Video
Here is a repost of Craigster05 post in the tech section
NPP Mufflers waiting for Install
Factory Exhaust Removed
Drilling a ¼” hole in the rear well
Run the Vacuum Tube though the hole
Run the Vacuum tubes through existing frame locations
After dropping the rear sway bar, snake the NPP mufflers up and over
Attach the pipes to the mufflers
Connect the vacuum hoses to the NPP mufflers
Make sure your muffler pipes are straight and level
Muffler hardware done and vacuum tubing run
Locate vacuum nipple in well
Place NPP controller in bottom and attach vacuum and power lines
Place lid on top, you can still store items here (Does that look perfect or what???)
Connect power cable to the Seat Heater Fuse
And of course, a quick run with Ed's Polishing kit
That's all there is to it.....All that's left is to go out there and have a blast with your new found customized sound.
BTW: Do all Vettes have Heated seats? I have the 1LT group package.
Nice system Ed, still loving it.
It's very easy to do, most of the wire just tucks under the carpet in the rear and the sill trim in the front. I have a vert so I had to deal with a bit more fun staying clear of the top mechanism and passing the wire into the front but it was still very easy to do.
I installed Z06 mufflers and the LG Z06 headers along with Ed's system. GOD ALMIGHTY what a beautiful noise. Closed they sound great, like the car should come from the factory. Open... bring the thunder, when you're at WOT it's like a race car.
I sure would love this system. I just can't justify the buying the NPP mufflers right now....Oh the pain! I want one
