*** Light Bulb Replacement ***
Old Aug 15, 2008 | 09:33 PM
HorsePower Junkie's Avatar
HorsePower Junkie
St. Jude Donor '20-'21-'22-'23
Default *** Light Bulb Replacement ***
I've seen pics of the removeable plastic panel in the fenderwell in front of the front tires that allow access to the turn signal/daytime running light bulbs, and see how those bulbs are removed and replaced. Also have seen the larger panel removed to access the fog light bulbs.
But how do you remove and replace the High Beam and Low Beam bulbs please? Any pics would be most appreciated.
Many Thanks,
- HPJ -
PS.
If you'd like to also post your favorite Low beam, Fog light, and DRL replacement bulb choices, please do so. Especially bulbs (not HID kits) you have found that match the stock Low beam color better, and/or bulbs that produce better visibility, especially high beams.
Thanks again!
Old Aug 16, 2008 | 11:54 AM
HorsePower Junkie
Anyone have any links to how to change the low beam bulbs?
Old Aug 16, 2008 | 02:28 PM
*FAÇADE*'s Avatar
*FAÇADE*
PHOTOSHOP SPECIALIST
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
These two links might help:
http://www.exoticvette.com/HID.pdf
http://www.exoticvette.com/xenon.pdf
Old Aug 16, 2008 | 03:33 PM
HorsePower Junkie
Originally Posted by FAÇADE-C6
Great instructions with nice pics for Fog Light Bulb replacement. Many Thanks FAÇADE-C6, you are sincerely appreciated!
Anyone have a link or pics of how to replace the Low Beam Light Bulbs please?
Old Aug 16, 2008 | 04:43 PM
*FAÇADE*'s Avatar
*FAÇADE*
These are instructions from the owner's manual:
. . . and this is a link for DRL bulb replacement - - but access to the headlamps would be the same:
http://forums.corvetteforum.com/show....php?t=1585994
Old Aug 16, 2008 | 08:06 PM
HorsePower Junkie
Just what I was looking for, many thanks FAÇADE-C6!
To *** Light Bulb Replacement ***
