Is traction 100% off when turned off?
Old Aug 17, 2008 | 09:38 AM
Boomer111's Avatar
Boomer111
Default Is traction 100% off when turned off?
I understand that some manufacture systems aren't 100% disabled. How about the 08 C6.
Old Aug 17, 2008 | 09:48 AM
RussellZ's Avatar
RussellZ
Press and hold your button for 5 seconds and it will turn everything off. Then, be careful when driving!
Old Aug 17, 2008 | 09:49 AM
Boomer111's Avatar
Boomer111
Is this the same as competition mode?
Old Aug 17, 2008 | 09:57 AM
Boomer111's Avatar
Boomer111
OK is I did the search and got my answers.
Traction control off is just that...AH remains on
In comp mode TC is off and AH remains on but with higher tolerances for sliding or drifting the car (like you want on a road course).
Pressing and holding the button will shutoff both TC and AH.
Old Aug 17, 2008 | 10:13 AM
BEZ06's Avatar
BEZ06
Yes - you've got it!!!
However, I'm not sure you've completely answered your own question.
In addition to TC, there is another function built into the PCM - and that's TM (Torque Management).
When I first read your original question I thought you might be talking about TM rather than TC.
We can control TC and AH with the button on the console, however TM can only be tuned out with tuning software such as HPTuners, EFILive, LS2Edit, etc.
TM was programmed into the PCM to limit power to protect drive train components, and it will pull power on you to do that. If you don't want it, you'll need tuning software (or a tuner) to program it out.
Bob
Old Aug 17, 2008 | 10:25 AM
haljensen's Avatar
haljensen
And don't forget the "other" traction control on the car, the limited slip differential.
Electronic TC by the ABS brakes that can be disabled completely and mechanical TC by the clutch type differential that can't be disabled unless it breaks.
Old Aug 17, 2008 | 08:22 PM
Boomer111's Avatar
Boomer111
Mine is a mn6. I was wondering if the torque off is 100%. I believe it is now.
Old Aug 18, 2008 | 12:59 AM
headhunter1975's Avatar
headhunter1975
I thought the MN6 didn't have torque management?
To Is traction 100% off when turned off?
