Lowering, removing bolts all together???
Old Aug 18, 2008 | 01:57 PM
vettethret's Avatar
vettethret
Default Lowering, removing bolts all together???
For the people that want their cars low without doing coil overs, and with all the problems with lowering bolts, has anyone left the bolts out all together? I always do coil overs(not for another 3 months) and am temporarily going to slam the car without coil overs, I've never seen a post with someone removing the bolts all togther for extreme lowering, it this possible?
Old Aug 18, 2008 | 02:09 PM
SL33PER's Avatar
SL33PER
Possible, yes, good idea no. The bolts are there to keep the suspension parts from hitting eachother and to provide a little cushion with the bushing. If you remove it all together you will probably have metal on metal makeing a horrible noise and also causing wear.
Old Aug 18, 2008 | 02:30 PM
vettethret's Avatar
vettethret
O.k. Thanks I didnt know that. I only have experience with coil overs and not with the bolts. Looks like I'll just have to suck up the WCC bolts for three months. Thanks for the info!
To Lowering, removing bolts all together???
