Indexing spark plugs
Old Aug 19, 2008 | 11:47 PM
jjas's Avatar
jjas
Default Indexing spark plugs
Does anybody index their spark plugs? I read an article that showedindexing will add about 10% to the performance of an engine. Like to know if anybody on this forum is doing this. Thanks.
Old Aug 20, 2008 | 01:04 AM
3 Z06ZR1's Avatar
3 Z06ZR1
I regularly index them. I don't use the washers anymore. I just start with 16-20 plugs for the ol V-8.
I notice better faster starting. Smoother over all, not going to get 10 percent. Jacob's electronic's really tested extensively and said it's 1 1/2
hrs per cly. for each thats schrounding it's own spark.Plus it gives a balanced output. I really feel each time i've done it. That it was worth the trouble! About 10 oclock for the ls motors
Old Aug 20, 2008 | 03:21 AM
lockman's Avatar
lockman
ok someone please explain to me what this is please. I have never heard of it before.
Old Aug 20, 2008 | 07:45 AM
EuroRod's Avatar
EuroRod
Only people that I knew that indexed there plugs were the ProStock boys, and I think even they have stopped. Too much work for 1/2 hprsepower.
Old Aug 20, 2008 | 07:52 AM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Indexing is adjusting the spark plug so all the ground electrodes are in the same position to maximize the spark exposure to the cylinder.
Here is a link to an article to explain it.
http://www.fordmuscle.com/archives/2000/07/indexplugs/
Old Aug 20, 2008 | 08:55 AM
Michrider's Avatar
Michrider
If it gave you 10 percent more performance every auto manufacturer would be doing it on every engine. I had it work good on a nitrous big block that was misfiring under a big nitrous shot. But that has huge cylinder pressure, and really old style combustion chambers.
I think a lot more thought has gone into combustion chamber design to allow for the electrode variation. With emissions and fuel economy legislation so tight, if there was a hint of incomplete combustion there'd be something done pretty quick.
In a modern OEM engine I doubt it means a hill of beans. Dyno tests can be deceiving. Do test A get X results. Change parts do test B and WOW got Y results. What they don't tell you is the oil is now hotter from the first test, pistons have expanded, rings sealing better ...
That's why all the snake oils add their products for test B.
Then there's the psychological factor. I did all this work, wow does it really feel like a big difference.
I'd say if the chambers have some shrouding issues around the plug, might be worth a try. If it's a half way decent designed chamber, probably not going to mean much of anything. I'll bet an oil change and fresh air filter gives you better results. And for some real results, find a good tuner - that's real hp magic to be had there.
Old Aug 20, 2008 | 09:52 AM
FloydSummerOf68's Avatar
FloydSummerOf68
It takes about 15 seconds per plug to index it...so why not check to make sure they're gapped correctly?
Old Aug 20, 2008 | 10:56 AM
3 Z06ZR1's Avatar
3 Z06ZR1
Worth it everytime!
Old Aug 20, 2008 | 11:59 AM
autoxnut's Avatar
autoxnut
Indexing is not about setting the sparkplug gap. It is about orienting the plug so the open side of the electrode is pointed to the intake valve. This way the air/fuel charge does not have to travel around the electrode before ignition. A lot of SCCA autocrossers running in classes that do not allow engine mods take the time to perform this task, as every small improvement counts.
Old Aug 20, 2008 | 12:06 PM
C6~Missle's Avatar
C6~Missle
I used to index my plugs in the ole days.. with one coil pack per cyl... I really don't think it matters much anymore.. more than enough spark even if its facing away.. but it can't hurt..
Old Aug 20, 2008 | 12:07 PM
FloydSummerOf68
Oh I see...my mistake.
Now that you say that I do remember that...guess I just wasn't thinking very well before
Old Aug 28, 2008 | 04:16 PM
OWENMUSTANG's Avatar
OWENMUSTANG
In my SBF's indexing seemed to help the idle. I didn't notice a SOTP improvement though.
To Indexing spark plugs
