Calling all LS2 A6 Dyno Sheet holders...
Old Aug 20, 2008 | 08:10 PM
A-Pex's Avatar
A-Pex
Default Calling all LS2 A6 Dyno Sheet holders...
Hey Folks!
I've been trying to get a good idea of what a "bone stock" LS2 w/ A6 dynos so that I can get a decent idea of the paracitic loss % from the A6 driveline.
Why am I doing this when I own one myself? Partly, because I'm an idiot and didn't dyno my car before I started modding. :o And, partly because a single data point does not make fore a reasonable sample.
When doing my research here on the forums, I've found only a few posts referencing stock HP #s for the A6's and they were anywhere from 315rwhp to 340rwhp, but I never saw any real dyno sheets to correlate them to.
So here is my request, should you feel so inclined:
1) If you have an LS2 w/ an A6 and you have your "bone stock" dyno sheets, please post them.
2) If you provided your "bone stock" dyno sheet, please feel free to provide your modded sheets as a comparo.
This way other folks that might be interested in doing your same mods will be able to see what potential results fthey might expect.
I'd post mine here but not only have I already done so in other forums and as I said above I'm an idiot and never dyno'd in "bone stock" condition.
Old Aug 21, 2008 | 08:14 AM
Bushong572's Avatar
Bushong572
I can't find my stock dyno, but my car made 335 rwhp (bone stock). I've seen several A6 cars run on a Dynojet....this is pretty much the average.
As far as drivetrain loss.....be prepared for a heated discussion. There may not be an exact formula, but I can tell you what I've seen. A6=17% loss MN6=12%
loss I have seen several LS2 ENGINE dyno sheets
(NA and supercharged) then compared the later Dynojet rear wheel numbers (A6 and MN6) These losses seem to hold pretty true.
Old Aug 21, 2008 | 08:52 AM
c607z51's Avatar
c607z51
bone stock 330.92 rwhp 341.07 rwt
after mods.: kooks 1 3/4" headers w/catted x-pipe, vararam, tune, and ghl exhaust. the numbers went up to: 359.3 rwhp and 358.32 rwt.
Old Aug 21, 2008 | 09:14 AM
AintQik's Avatar
AintQik
I told ya. Ya made 20 more rwhp and better than that through out the band. What, you don't believe my super calibrated eyeball dyno with seat o the pants adaptor? You have the special AintQik FAST manifold. Its like the highlander, there can only be one
By the way, you need to stop by and check out the giant shiny thing bolted to the front of my motor.
As far as % lost... that is indeed going to be a heated debate. One of the things I've noticed, is that with a higher horsepower car, the % doesn't really hold true. Is seems once you break 550 rwhp or so the loss becomes almost standard. My car made 520. So, at the motor it was making 582. At 750rwhp the motor is not making 840. There seems to be a point where it just loses around 40~50 rwhp and the percent loses accuracy.
Don't sweat the numbers. The stuff we are going to hook you up with is proven. I wouldn't steer ya wrong.
Old Aug 21, 2008 | 03:32 PM
Evilways's Avatar
Evilways
Stock: 337/317
L92 as cast heads,L76 intake, cam,exhaust ,tune: 450/405
Old Aug 21, 2008 | 04:56 PM
dbratten's Avatar
dbratten
Not quite bone stock as I had the Vararam CAI installed on the first pull.
Final pull reflects tune. No other mods. All pulls in 4th gear run up to 175 mph.
--Dan
Old Aug 21, 2008 | 08:10 PM
NYC6's Avatar
NYC6
Sorry cant find my print out right now. 345 totally stock and 362 after LPE intake,LG Pro's, Vette Dr tune. 17 hp on the top end but 35-40 increase in the heart of the powerband.Tq increases similar but forgot actual #'s.
Old Aug 21, 2008 | 09:58 PM
Ted P's Avatar
Ted P
bone stk 328 rwhp 341 rwtq
kooks headers, x pipe, magnaflow catback, callaway honker, hp tune
375 rwhp
376 rwtq
Old Aug 22, 2008 | 03:00 AM
A-Pex's Avatar
A-Pex
Wow! Thanks guys! Keep the stock and modded numbers coming!
Looks like so far the stock HP#'s are ranging from 328 to 345 and TQ#'s are ranging from 317 to 341 at the rear wheels.
As AintQik illuded to, I'm not just interested in what the stock numbers were but rather using them and the modded #'s to determine if:
a) There is a standard % lost due to driveline
-or-
b) There is a standard # of HP/TQ lost due to friction from the A6 driveline
Heck, I know whatever magic AintQik and SpinMonster work on my car I'll be happy with! Interestingly enough, we never discussed my theory prior to his post. He must be smart or somethin'.
My guess was that due to a relatively constant amount of friction within the driveline, once that friction is overcome all future mods might result in a relatively linear increase in hp/tq #'s vice a percentile of the total generated at the crank. And, it seems that AintQik has seen these results (at least to some degree) in the real world.
Right now it's more of a very rough theory and there's a very good chance there's no way to definitively answer the question. That is unless it were possible to compare a single A6 LS2 with and without the associated mods (e.g. CAI, FAST, Headers, etc.) both at the crank and at the rear wheels.
Again, please keep those stock and modded #'s coming. I'll do the same with mine as future mods are added by AintQik and SpinMonster!
BTW, my AintQik ported and SpinMonster FAST install resulted in 350HP/360TQ @ the wheels. Thanks again guys!
Here's a bit of the methodology for those who are interested...
If we assume the mean HP and TQ numbers of 336.5 and 328.5 respectively are an accurate sampling (and we can not without more data points) that's about a 15.8% (or 63.5 HP) loss in HP and 17.8% (or 71.5 lb-ft) loss in TQ due to driveline friction. If I gained 13.5 peak RWHP and 31.5 peak RWTQ from the mean values (which is higly suspect due to my lack of initial data) then we can start to work out the answer to the question.
In reality, we'll need to use many more data points to get a good sample before we can really determine if we even have a shot of answering the question.
Once we've collected some more data, and I get some time to work the numbers (and hopefully figure out a way to extrapolate the % v.s. friction theory) I hope to provide you all with the findings (if they turn out to be at all relavent).
Yes, I"m a bit of a science geek. Yes I like to know exactly how things work. And, no I don't believe anything I read on the interweb without testing and evaluating the data.
More to follow...
Old Aug 22, 2008 | 08:05 PM
tmak26b's Avatar
tmak26b
You have to ask people what dyno they are using too, dynojet and other dyno can change as much as 30hp
Old Aug 23, 2008 | 03:32 AM
kermooni's Avatar
kermooni
Dynojet ...
Stock:
337 HP, 338 Tq
Kooks 1-7/8" JetHot coated, catted x-pipe, Corsa Sport, LPE CAI, tune:
378 HP, 375 Tq
Be careful comparing - A6 in fourth gear is not 1:1 gear ratio like MN6.
Old Aug 23, 2008 | 04:41 AM
Z51Semper's Avatar
Z51Semper
This is good information for me. I've been looking for stock hp\torque numbers just to see them. Good thread, OP.
LS2-Zomb!e's Avatar
LS2-Zomb!e
My A6: 331 HP
My M6: 364 HP
To Calling all LS2 A6 Dyno Sheet holders...
