Fast 92
Old Aug 23, 2008 | 02:39 PM
Night Stalker's Avatar
Night Stalker
Default Fast 92
I want to order a Ported, and fire wall cut FAST 92 Intake for my LS2. Who is the best at porting these intakes? Where is the best place to order one?
Thanks for the help!
Old Aug 23, 2008 | 03:07 PM
LS1LT1's Avatar
LS1LT1
Cartek Racing has done some fine porting jobs on the FAST (and stock) intake manifolds.
The same proven workmanship/skill that has made their many years of cylinder head porting so successful has also been applied to their intake and throttle body work.
www.cartek.net
Old Aug 23, 2008 | 03:15 PM
The Clevite Kid's Avatar
The Clevite Kid
St. Jude 15 Year Donor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
Part of a complete porting job is to match the ports on the manifold to the ports in the heads. If you are having ported heads installed, the installer should be able either to match the ports himself, or arrange for it to be done. Talk to the installer of your heads.
If you are running stock LS2 heads, then the cleanup and mods by SpinMonster will give you a package you can install yourself, and will not be exceeded by anyone else NOT having access to your heads.
Old Aug 23, 2008 | 03:18 PM
LSCHLEM's Avatar
LSCHLEM
Sen it out to SPINMONSTER. He will do all the mods, & PORT it . A tried and proven guy. Other great porters are CORY HARRIS and JEREMY FORMATO.
Old Aug 23, 2008 | 05:16 PM
SpinMonster's Avatar
SpinMonster
All you need to know about my porting and prep work:
http://forums.corvetteforum.com/show....php?t=2102596
I was a little behind on these things but I'm about caught up. The last of the current orders will ship Tuesday.
Old Aug 23, 2008 | 05:18 PM
A-Pex's Avatar
A-Pex
Though AintQik did my porting job and SpinMonster modded it to fit my 06.
I'm VERY happy with the job. Resulted in a VERY flat tourque curve and a peak of 250HP/260TQ as my only mod!
Old Aug 23, 2008 | 05:24 PM
SpinMonster
I think you mean 25/26 rw?
Old Aug 23, 2008 | 06:33 PM
A-Pex's Avatar
A-Pex
Good Catch! I actually I meant 350/360, I must need some sleep... LOL
Those are my TOTAL RW dynojet numbers after the FAST, not the increase.
Old Aug 23, 2008 | 06:48 PM
Nightstalker Medic's Avatar
Nightstalker Medic
Mr. Spin is the person you want to do your port work on our FAST 92.
You will not be sorry!!!
To Fast 92
