Service Traction Control & Active Handling
Old Aug 27, 2008 | 08:18 PM
05vettelag's Avatar
05vettelag
Default Service Traction Control & Active Handling
A couple weeks ago i got a Service active handling msg and read where it could be the telescoping wheel on my 05 since i had it all the way out and i put the wheel about half way out and it never came back on until about 5 mins ago i got the msg in the DIC again. I put the steering wheel all the way in and drove for about 15 miles and it never came back on. does this sound like the harness issue with the steering wheel or something else. Thanks for your help
Old Aug 27, 2008 | 08:50 PM
steve kub's Avatar
steve kub
3rd Gear
Check your tire pressure
Old Aug 27, 2008 | 09:04 PM
05vettelag's Avatar
05vettelag
30 all the way around
Old Aug 27, 2008 | 09:36 PM
patton's Avatar
patton
St. Jude Donor '09
i need a code to help you
Old Aug 27, 2008 | 09:56 PM
05vettelag's Avatar
05vettelag
i checked with HPT and there were no codes
Old Aug 27, 2008 | 10:19 PM
patton's Avatar
patton
St. Jude Donor '09
use a scan tool,check for history codes
Old Aug 29, 2008 | 12:28 PM
Wass's Avatar
Wass
St. Jude Donor '09-'11
Yes, sounds like the harness issue. I had mine fixed under warranty two years ago, but it recently came back. However, if I move the steering column up & down or in & out it goes away for a few weeks. I have to get it back in the shop. Good luck!
Old Aug 29, 2008 | 02:12 PM
05vettelag's Avatar
05vettelag
thats what mine does. thanks
Old Aug 29, 2008 | 02:42 PM
Wass's Avatar
Wass
Glad I could help!
To Service Traction Control & Active Handling
