Help, my battery died...
Old Aug 29, 2008 | 04:07 PM
A-Pex's Avatar
A-Pex
Default Help, my battery died...
This is a Simple Battery Replacement Question...
What battery would you recommend replacing the stocker with for the stock location and why?
Old Aug 29, 2008 | 04:23 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Odyssey from SummitRacing or Jegs, or Sears Platinum.
Old Aug 29, 2008 | 04:37 PM
saplumr's Avatar
saplumr
Optima red top.
Old Aug 29, 2008 | 05:13 PM
John D.'s Avatar
John D.
Just go with a stock battery unless you drive your car dailey. If car is sitting for any lenght of time your battery will drain on you. Buy a standard battery and a good battery tender.
Old Aug 29, 2008 | 05:16 PM
ROD BROWN's Avatar
ROD BROWN
Default Go stock
Just replaced the battery in my 06 w/a stock battery.The warranty on the new batterys is 6 years.Thats good enough for me and it was free.:flag :
Old Aug 30, 2008 | 12:06 PM
calemasters's Avatar
calemasters
What battery would you recommend replacing the stocker with for the stock location:
The AC Delco Professional series battery
Why:
It is a high quality battery, it fits properly, the terminals are correct and the tie down is correct, & good warranty. Simply put, it is the correct battery for the car.
Old Aug 30, 2008 | 07:20 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
My OEM Delco died suddenly with no warning right at 3 years. Because I've had issues with sudden death and leaky Delco batteries (with side terminals), I have no problem with using another brand. I did some research and found Interstate brand makes one that dropped right in. The terminals are in the right position and it was the same size.
I moved the labels from the Delco OEM battery and stuck them over the Interstate labels to fool people. They fit perfect.
Old Aug 30, 2008 | 09:33 PM
saplumr's Avatar
saplumr
Seems like the factory batteries are on a 36 month timer.
Old Aug 30, 2008 | 09:59 PM
redline_ken's Avatar
redline_ken
I've read on here about the factory batteries going after 3 yrs without warning, so I just installed an Optima red top in my '05. It only cost me about $123, after the rebate, from Advance Auto.
Old Aug 30, 2008 | 10:08 PM
*FAÇADE*'s Avatar
*FAÇADE*
PHOTOSHOP SPECIALIST
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Optima Yellow Top D34 in my '07 Vert.
To Help, my battery died...
