Just as an update. My buddy installed the Heat Soak Reduction Kit on his G8 GT and he claims it has made the biggest change in overall performance that he's felt on any of his recent cars. If I decide to try it on the vette I will post my results.
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Originally Posted by NHRA95
I had the same surging problem with my 08 LS3. It seems like the MAF doesn't like any kind of turbulence.
My new Z06 has the same idential surging problem when I tried to alter airflow from outside air. Anyone have a solution which seems to be an ongoing problem with 08's. Will a tune correct this?
Just an idea, but do you think placing a fine mesh screen over the hole reduce the turbulence? It would act like a baffle. Worth a try.
It is for the LS2, NOT the LS3...Apparently it replaces the IAT sensor with one that responds faster to actual heat changes. On the LS3 it is integrated into the MAF sensor and responds Very quickly as observed on my Scangauge so not needed with 08's and newer..
I have seen my iat`s drop from 85 degrees to 75 degrees at 60mph, and from 75 degrees to 68 degrees at 100mph with the vararam. I logged the run and this was my findings with the iat temps. I have several logs showing this drop. This was an 1/8 run.
Modshack,
You have a very nice setup.
Have you ever logged from 0-100mph to see what the iat temp differences were with your setup?
I added the Halltech Beehive to my Vette-Air/K&N set up today. I fabricated a baffle that sits on top of the Vette-Air to divert the incoming airstream to the sides of the filter and air-box. Seems to be working as the surging is gone.
