P0700 & P0711 codes???
Old Sep 1, 2008 | 10:59 PM
z06_23_45's Avatar
z06_23_45
Default P0700 & P0711 codes???
The check engine light came on on my convertible. I went to AutoZone and they ran the scanner on it for me. These are the 2 codes that came up: P0700 & P0711. Is this something I have to worry about or can I just have them reset the codes and go on my way? Any help is appreciated.
TIA,
Mike
Old Sep 1, 2008 | 11:17 PM
patton's Avatar
patton
St. Jude Donor '09
TIA,
Mike
mil light requested/trans temp sensor
Old Sep 1, 2008 | 11:22 PM
BEZ06's Avatar
BEZ06
Here's what they refer to:
DTC Codes - P0700-P0899 – Transmission
  • P0700 Transmission Control System Malfunction
  • P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
Are you still under warranty? If so, drive it down to the dealer.
Do you have an auto or manual transmission? I'm assuming auto.
It might be a transient problem. I'm reluctant to advise you to do something that would really damage your transmission, but if it were me I think I'd clear the codes, check transmission fluid level, and drive it a while. I'd also try to see if all wire connections going to the transmission sensors are connected properly. If it comes back on I guess it would be time for a visit to the dealer even if you won't have warranty coverage.
Good luck!
Bob
Old Sep 2, 2008 | 12:13 AM
z06_23_45's Avatar
z06_23_45
Yes it is an auto trans. Everything seems fine as nothing feels out of whack. I guess if I clear the codes and the problem is still there the light will come right back on????
Old Sep 2, 2008 | 09:13 AM
KarlK's Avatar
KarlK
From: Beats UD regularly playing 3D chess, and at life
I had same codes. Mine triggered in high heat conditions, using paddle shift and engine coolant was 220+ degrees, didnt check tranny temps, probably right up there. Cleared codes, changed tranny fluid and testing right now.
To P0700 & P0711 codes???
