Reset Transmission code?
Old Sep 3, 2008 | 01:47 PM
SkyKing421's Avatar
SkyKing421
Default Reset Transmission code?
My local dealer says the transmission has set a code that is preventing the cruise control from working. Doesn't show on the DIC and the transmission works fine.
Is there a way to reset (delete) that transmission code and NOT lose all my other settings, as I would by disconnecting the battery? Maybe the TCM fuse?
Thanks in advance for all the help, to others, from the dedicated experts here. Great job!
Old Sep 3, 2008 | 03:49 PM
Mark Lohr's Avatar
Mark Lohr
I am afraid that I can't answer your question on resetting the trans codes but I can tell you that my 2007 A6 did the same thing and the dealer had to replace the valve body. It was fine for a thousand miles or so until this week when it dropped out of cruise on it's own. I was able to reset the cruise immediately but I'm not happy. The dealer and I are going to have another talk. Please post whatever solution you or your dealer come up with. Thanks
Old Sep 3, 2008 | 04:19 PM
SkyKing421's Avatar
SkyKing421
I fixed it. At least temporarily.
I deleted the codes by pulling the two TCM fuses, #1 and #11, in the engine compartment. After replacing the fuses, the cruise works again and I did not lose any of my settings, such as, radio, seats, etc.
If it happens again, I'll let them work on it. Until then I'm spared the anxiety.
To Reset Transmission code?
