Who has a cammed a4 ,how do you like it,idle,and driveability?I am going to put one in my c6 a4 and need some feed back please.
I wouldnt go too big with out getting a converter. You can get them to run and idle perfect when using an aftermarket converter. Feel free to PM me if you need any more info.
I am running a Comp Cam in my A6 and I love it, but as Frans96ss stated that you can't go to big without a converter.
I have a nice cam lope (which I wanted) and I have no driveablity issues the car will idle and have no problems with running the air. I am running my stock converter and the cam I have is about the largest you can run without having to change converters.
Tonyb4 Thanks for the videos your car sounds great and really goes. Do you know the numbers on the cartek 3x cam? Hows the drone and did you notice any differance in fuel consumption? I beleave you have a pully as well on your car.
Forgot about the ASP pulley,its 10%.
The car drone is from 15-1900 rpms and its not bad at all. Gas mileage,believe this or not, actually stayed the same on the thruway and lost about 1-2 on the street.
