Halltech Beehive Venom™ RAIS
Old Sep 5, 2008 | 03:56 PM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
Default Halltech Beehive Venom™ RAIS
We just finished the template for the 05-07 C6 Halltech Venom™ Beehive Ram Air Induction Shroud™.
We should have these in stock in about two weeks. Check with Southern Car Parts late September.
We are able to use the same shroud as used on the Z06 and LS3 C6, but the hole alignment is different due to the difference between the stock AIS vs the stock pin alignment on the LS7 and LS3. The pin locators on the LS2 are going to be changed to fit the Venom™ Beehive. We have not tried this shroud on the older Halltech C6 Stinger SSM, but it should work on that application as well, since the SSM filter is actually shorter in height compared to the Killer Bee Filter that comes with the Venom.
Introductory pricing will be $129.99 plus shipping on the Beehive Venom™ RAIS shroud.
Beehive RAIS on the LS7
Above HP rating is on the LS7 with Halltech e-mailTune®. e-mailTune® is no longer available for street applications.
__________________
"World Class Performance for your Corvette"
Intake Design and Engineering since 1999
Halltech Systems, LLC
423-915-6056
For service email:
orders@halltechsystems.com
www.halltechsystems.com
Old Sep 5, 2008 | 04:23 PM
Deftly's Avatar
Deftly
What are the advantages of this item? Is it strictly to keep the hot engine air from getting to the filter?
Old Sep 5, 2008 | 04:41 PM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
Hot air out, cold ram air in; Intake Air Temp Sensor pulls timing at 86F. The Beehive isolates the filter from hot air, and keeps the ambient air ramming into the filter. No claim of ambient plus, but with the Ram Air Ports cut, you should have at least as much airflow to the filter as other Ram Air Systems. Water will drain right back out the ports and are directed to the sides of the filter, not directly on it.
Install Instructions:
http://www.corvettels7.com/Instructi...iveInstall.pdf
Old Sep 5, 2008 | 04:53 PM
Deftly's Avatar
Deftly
Thanks.
How important is the rubber hood seal? I have a Speed Lingerie Super Bra since it uses a velcro attachment where the hood seal seems to go.
Old Sep 5, 2008 | 05:05 PM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
Thanks.
It helps keep the Ram Air from leaking out the top, but the shroud is not sealed anyway. It has other areas of leakage, so the seal is not critical.
Without the mini-gun, I'm just a regular bee.
Old Sep 5, 2008 | 07:10 PM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
Originally Posted by fafnir
after looking at your website, there seems to be multiple filters types available, or at least implied;
can you elaborate of the differences between your "standard" filter media, the "iso" filter media, and the "race" filter media
and also if there is a difference in the filter media between the LS3 type and the LS7 type intake?
e.g. not in terms of flow since obviously the race filter flows more, but in terms of filtration efficiency, filtration capacity, filter durability, and if there is a difference in how the filters are maintained?
thanks for the time
_
The filter provided with all Venoms is our ISO 5011 Certified 8 layer filter. 99.4% efficiency rating.
You can request the K&N style 4 layer filter for no additional charge, in your order. It is worth maybe 1 HP at full tilt according to Katech. The Race version is good for 2 HP over the ISO 5011 filter on their engine dyno, so unless drag racing is your thing, there is some filtration of sand, grit, grime, but not much dust since the Race version is Dupont Reemay, and does not hold oil.
Oil is the primary filtration defense along with the cotton gauze.
http://www.halltechsystems.com/product_p/kbraisv.htm
Old Sep 5, 2008 | 08:51 PM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
so to rephrase, if i'm not really interested in the last 2hp, there are no advantages to the other filter media types and less filtration as well when compared against the "standard" or "iso" filter media type right?
also, if you don't mind, can you post a picture of how your "Halltech Beehive Venom RAIS" attaches to the radiator? e.g. push pins, plastic studs, etc?
and also, would you say that the material used in the plastic part of the killer bee intake would survive a powdercoating oven?
say if i wanted it to be powdercoated to match a bunch of other stuff and not painted?
thanks again for the time
_
We do not have pictures. It looks exactly like the picture shown since it is the same shroud, with a slightly different pinout.
Killer Bee will not survive powercoating since it plastic cannot be powercoated.
Katech paints our Killer Bee to match exteriors.
To Halltech Beehive Venom™ RAIS
