Please help now koni fsd install
Old Sep 8, 2008 | 06:47 PM
STRAFER's Avatar
STRAFER
Default Please help now koni fsd install
Just started rears and and not sure if big white spacer that fits under boot of old bilstein wants to go on koni shaft. Also i assume i put old boot on koni, but it doesnt fit, do i ream the hole in the boot a little bigger. I tried search which i had done all week, but now the search isnt working. Does everything of the bilstein rears just go back on koni, and if yes do i have to do any reaming. No instructions in koni kit. Getting dark, please advise asap. Must have put in 100 shocks over the years dont know why this isnt going smoothly. C6 08 z51. Thanks.
Old Sep 8, 2008 | 07:20 PM
REVAK's Avatar
REVAK
Default Koni info
When I put the Koni' s on my 06 Z51 I reused all the factory hardware, reamed or drilled as necessary to fit. I am not familiar with the bilstiens, however I would use the hardware that was the most substantial, and trust your previous experience. Good luck........
Old Sep 8, 2008 | 10:04 PM
MontereyRedC6's Avatar
MontereyRedC6
Cruise-In IX Veteran
St. Jude Donor '09
Maybe too late. But the big white bump stop came from the stock shocks when the Bilsteins were added. Use that and ream the black factory cover to fit with a rat tail file or carefully with a smaller bit. Not too much. No extra play. Just enough to get them on. They will be stationary when complete. Re-use original top rubber bushings just as installed with washers top and bottom. Good luck.
Old Sep 8, 2008 | 10:26 PM
deanm11's Avatar
deanm11
Agreed. Definitely use the stock dust cover and you will need to drill or file the hole just slightly. I used a step drill bit.
Old Sep 9, 2008 | 02:19 PM
CMY SIX's Avatar
CMY SIX
for that kind of money KONI does'nt give you a complete set up?
Old Sep 9, 2008 | 04:37 PM
REVAK's Avatar
REVAK
Default koni
They do but most of us on this forum preferred the stock hardware. The Koni FSD's are great shocks on a C6, base or Z51.
Old Sep 9, 2008 | 04:57 PM
FU's Avatar
FU
Race Director<br><img src="/forums/images/ranks/7k-10k.gif" border="0">
From: HOME OF THE FREE. BECAUSE OF OUR BRAVE. Babylon NY
St. Jude Donor '06 thru '20
ZO6's too
To Please help now koni fsd install
